Lift Kit? - JeepForum.com
post #1 of 7 Old 07-12-2010, 01:24 PM Thread Starter
fatladyvalkyrie
Lift Kit?
I wont be doing any hard core off-roading for a while with this jeep I'm going to purchase. I'm looking at either BDS or rough country. I gather BDS' warranty is better, but for 300 dollars difference, is it worth it if I'm going to go larger eventually when I'm ready to pound the trails?
fatladyvalkyrie is offline
post #2 of 7 Old 07-12-2010, 03:28 PM
MWguy101
I have a 4 in rough country lift on mine and love it. I upgraded the shocks,the steering stabilizer, the break lines and got boomerange shackles all from rc. Mine works great. Get air tools if you can and torch if you can. The only thing I would suggest prior to installation is to put several coats of paint on the leaf springs to help prevent them from rusting. You may want to also look into getting a new rear drive shaft and slip yoke eliminator as well. I run 33's on mine with no issues. Rought Country is not a bad lift, it works good.
http://www.jeepforum.com/forum/f12/m...e-joy-1010946/
95 YJ, 4" RC lift, 33x12.50x15 Durtrac
MWguy101 is offline
post #3 of 7 Old 07-12-2010, 11:39 PM
WranglerRush
I have heard that BDS is a great lift, one of the best in fact. Rough country had a bad rep in the past but have heard they have gotten better. Still, the BDS will ride better and take bumps better. I used to be the guy that went with the cheap lift, but now I realize spending a few extra hundred dollars is well worth it.
1992 Red YJ 4.0 with 5 on the floor and 33's
WranglerRush is offline
post #4 of 7 Old 07-13-2010, 12:17 AM
MJMPC
How high do you want to go? I have a OME 2.5 and it rides great.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 7 Old 07-13-2010, 08:17 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Buy the jeep first.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is online now
post #6 of 7 Old 07-13-2010, 09:48 AM
ZeroGravity
I always suggest buying the best parts you can afford.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #7 of 7 Old 07-13-2010, 11:22 AM
dell2028
dell2028's Avatar
Figure out where you want to be in the end. Probably a good idea to figure out what you eventually want to do with it and then what size tires you will need. After that work backwards. If your gonna run some 33s and do some moderate wheeling I'd say get the 3.5" lift and then tires. Keep in mind larger tires require deeper gears. So if you have a 2.5L you may want to think about going to some 4.88 gears for the front and rear. You can also aquire parts and do several upgrades at one time.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 05:06 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 09:04 PM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 11:03 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 10:04 AM
