Lift help! - JeepForum.com
post #1 of 4 Old 05-29-2001, 07:37 PM Thread Starter
ballasbakker
Lift help!
I have a stock '87 4.2L Automatic and want to fit 31" tires or larger without changing gears, or doing anything too expensive. Got 1.25" shackle lift and would like to use them as well if possible. What lift would be best, what size lift and tire? It is a dayly driver aswell!! Thanks!
ballasbakker is offline
post #2 of 4 Old 05-30-2001, 12:37 AM
rayray
rayray's Avatar
My dad runs a 3" body and 32's. His rig rarely goes offroad. It works fine for a daily driver. We did throw an ez locker in the rear to tame the wild hairs
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #3 of 4 Old 05-30-2001, 10:24 AM
Tonka
2015 JK Wrangler
i'm running 31x10.50r15 BFG Muds with a slightly modified 2.5L 5 spd and stock gears
I hardly have the use of 5 th, but with a 4.2 you shouldn't have any problems.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 4 Old 05-31-2001, 12:33 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
31's on my '89 4.2 makes it a little rough with a headwind and 5th gear. You really have to be moving to be able to hold it in 5th gear.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
