Lift and FSR - JeepForum.com
post #1 of 2 Old 05-15-2001, 06:43 PM Thread Starter
reno
Lift and FSR
I have reading a lot of the mag's out there and a lot of post. But I still have a couple of questions. First has anyone had any expirence with the 4" lift from Currie Ent? if so, do you like it? I have narrowed my chioces of Lift kits down to ethier the RE 4.5" or the Currie 4". I could afford the lifts maid by National Spring or Alcan but the only reason that I don't go that route is because from my understanding you have to have the jeep completely outfitted with everything that you want on it so you can obtain the total wieght of the vehicle and then they build the springs based on this information. Since I am just Starting to build up my yj, it seems that it would be a waist of money to build a lift kit on it's current weight and then have it change latter, therefore the lift would settle more due to the increased weight. Atleast this is the inpression i got when I've talk to them. Has anyone gone this route. if so how do they flex? My next qeustion is, does anyone use the Front Shackle Reversal from M.O.R.E. I looke into most of them but I feel this kit is designed the best. I would like to know how it performs with or without the buggy springs? Are there any interferience problems with it? assuming 33" tires and 4" lift. will the 33's hit the fenders underful compression. if you could do it over agian would you still put on the FSR? I don't feel that I will use the buggy spring setup but just mount the shackles in the back. Lastly M.O.R.E. says that the FSR will add 1.5" lift to the front if I go with a 4" lift and this FSR kit then how do I level out the Back? I already have currie boomerang shackles (not installed) and don't say custome springs because that would defeat the whole purpose of the Currie or RE lift kit.
89YJ with sye (jb) 31's and 1.5" (SS) body lift.
reno is offline
post #2 of 2 Old 05-15-2001, 09:18 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Heya,
I have the Superlift 4" kit on mine, and so far so good. I haven't heard too many bad words about Superlift, the price was decent, and the ride is nice (used to be a smooth "cadilac" ride).
I have been considering the Shackle-reversal as well, and I was told the best thing to do is the reversal on the front (1.5" lift) and extended shackles on the rear (2" over stock) to level it out. One guy in our club has done that, 4" suspension, shackle reversal and body lift and he is able to clear 35" rubbers. He is running on his stock axles, and so far, hasn't had too many problems with breakage. Our area has a little rock, a little mud .. and tons of trees.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
