Lift Combo?? - JeepForum.com
post #1 of 3 Old 09-12-2011, 04:08 PM Thread Starter
93Rhino
Lift Combo??
My '93 YJ has a 1.5" shackle lift now running 31x10.50 with no problem. I would like to run a 33" with clearance so the tires don't look stuffed in the wheel wells. Would a 2" RC leaf kit coupled with the existing shackles be enough? Or would the 4" leaf kit be better? I was also thinking of a 2" leaf kit paired with a leaf over axle kit...any ideas?
93Rhino is offline
post #2 of 3 Old 09-12-2011, 04:59 PM
TheNewbie
You will need about 4" of lift to fit 33's. And you are already running dangerously long shackles. 1.5" lift shackles would have to be 7" long from bolt to bolt. That screws with your steering geometry and puts a lot of stress on the shackle hangers. I would NEVER run more than a 1" lift shackle.
If I were you I would replace those shackles and get some lift srpings at the same time. You can also look into flat fenders or TJ flares with trimmed metal to help clear larger tires.
If you are dead set on keeping those shackle you should be able to clear 33's with another 2.5" of lift. But you wouldn't ever catch my rig with 1.5" lift shackles on it. It's just not safe.
1995 YJ 2.5 - 4Ē RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 3 Old 09-12-2011, 05:03 PM
JustinSuth
i clear 35's with waggy springs, 5/8's shackle, and rear tj flares.
JustinSuth is offline
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 07:46 AM
which lift combo? petej200 TJ Wrangler Technical Forum 3 02-21-2009 09:47 AM
body lift / suspesion lift combo WhiteSox05 YJ Wrangler Technical Forum 5 05-11-2008 01:36 PM
Need Help On Lift Combo Domb1972 TJ Wrangler Technical Forum 2 12-09-2007 03:24 PM
Cheapest Lift/Shackle/body lift combo to fit 33s on a YJ davekear YJ Wrangler Technical Forum 2 07-24-2005 01:52 PM
