Lift & Brake Lines - JeepForum.com
post #1 of 5 Old 10-04-2001, 09:19 PM Thread Starter
JeeperJay
Lift & Brake Lines
How much lift (if any) can I put on my YJ before I need to consider brake line extensions?
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #2 of 5 Old 10-05-2001, 07:56 AM
OhYeah
It really depends on how much flexing you are doing. I have heard 4" should definitely have extended brake lines.
Peace,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #3 of 5 Old 10-05-2001, 08:25 AM
damonejeep
I would recommend you putting brake line extensions or new extended brake lines in if you plan to go over 2.5 inches of lift. WIth the new amount of lift, there will be more wheel travel, more so than the stock brake line lenght can handle. To be safe, plan on extending your brake lines, you will be happier in the end.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #4 of 5 Old 10-05-2001, 12:35 PM
Nightclaw
Just sitting flat and level, my factory brake lines were too short for my 3" lift!
I had Earl's Performance/Industrial Liquidators custom fab a set of braided lines, both front and rear. For the rear, I used the factory T-junction and rubber line, and got long braided lines to go to the drums.
'94 YJ Sahara Hardtop
4.0L / AX-15 / Stock NP231 / Stock D30 (open) / D60 (35-spline, Detroit locker, Moser axles) / rear disc brakes / 4.56 gears / Advanced Adapters SYE & CV Shaft / 33" BFG MT-KM's / Thorley Header / Magnaflow Muffler / BesTop Flares
Nightclaw is offline
post #5 of 5 Old 10-07-2001, 06:36 PM
osburn
osburn's Avatar
Just re-route the hard line. Disconnect the line and carefully bend (don't kink) the line and run it under the frame. The mount on top of the frame can still be used. Just run one of the bolts that hold your bumpstop in place through it. This is something that happens early on to all the YJs around here.
Matt Osburn
Score 1032
osburn is offline
Do I need extended brake lines for a 4in lift? soundersfc TJ Wrangler Technical Forum 19 04-20-2015 09:13 PM
Brake lines after lift? lturley YJ Wrangler Technical Forum 9 02-13-2008 06:19 AM
Need brake lines with lift? Hot Toddy TJ Wrangler Technical Forum 8 02-25-2007 09:43 PM
Brake lines after lift paul075 TJ Wrangler Technical Forum 5 06-09-2004 01:43 PM
Brake lines with 3.5 lift JeepJeep FunFun TJ Wrangler Technical Forum 5 04-18-2003 11:36 PM
