lift the body with a... - JeepForum.com
post #1 of 2 Old 12-19-2001, 10:36 PM Thread Starter
JYRUS
i have two 1 inch t-case lowering kits and a spare 1 inch disc. they are all aluminum. can i use these disc for a inch of body lift on a yj. i think there are only 9 mounts so all i will need is longer bolts right?
JYRUS is offline
post #2 of 2 Old 12-20-2001, 07:02 AM
Newfie
There are 11 body mounts in a YJ
- 2 behind the gas tank
- 2 in front of the gas tank
- 3 (6 total) under each rocker panel (sides)
- 1 in front (middle of the grill)
They are not all the same size either. You might want to check the size of the bushings and generate your pucks from that. HTH
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
Body Mount/Body Lift problems need help! muddy8jeep8 TJ Wrangler Technical Forum 0 02-03-2009 03:53 PM
JK Body Lift? Rock Sliders Move WITH BODY? trowand JK Wrangler Technical Forum 17 01-04-2009 04:34 PM
Installing body lift, Cant get the front body mount off... swsscb TJ Wrangler Technical Forum 3 11-07-2008 10:23 PM
Body mount damage - Body lift help Drew43 TJ Wrangler Technical Forum 5 01-31-2007 09:39 AM
to body lift or not to body lift? atlas trouble twistedtj TJ Wrangler Technical Forum 9 08-21-2003 01:35 AM
