Quantcast lift blocks - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > lift blocks
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 11-26-2005, 01:21 PM   #1
murgg
lift blocks
im goin SOA and was thinking about a .5-1" lift block. has anyone done this, experiences. i know the longer the blocks the more axle wrap but im planning a a trac bar anyways and its only 1 inch. i've also ready not to put lift block in the front, why not? i figured it be alright at only 1 inch and i was goni to make my own with two prongs to go into the perch.any thoughts?
89 yj SOA 8" lift total all suspension, 36" TSL"s 4.88's 8.8 rear and the almighty 4.2L
murgg is offline   Reply With Quote
Old 11-26-2005, 03:00 PM   #2
jeffy
Why not just get leafs that are .5-1" taller? Even with a traction bar (not track bar) you may still experiance some axle wrap. Lift blocks are a no-no in the front.
www.4BangerJP.com
A Pitiful RigRater Score: 789RRv1.0
jeffy is offline   Reply With Quote
Old 11-26-2005, 03:40 PM   #3
murgg
cost is why im not getting new leaves.i know there a no-no in the front but i want to no why?
Old 11-26-2005, 04:38 PM   #4
D-train
just get .5" - 1" lift shackles
D-train is offline   Reply With Quote
Old 11-26-2005, 04:54 PM   #5
RAYMAN975
yea, lift blocks are stupid get a 1/2" shackle lift and 1" body lift, youll be better off, or just trim your fenders
RAYMAN975 is offline   Reply With Quote
Old 11-26-2005, 06:38 PM   #6
fratis
fratis's Avatar
depends on how its executed. i turned the bottom (shortest) leaf upsidown so it had less effect on springrate and allowed more uptravel. this in effect is a 3/8" lift block. the difference is it is bolted together with the spring pack. if you were to use a 1" thick "leaf" bolted directly to the springpack with the center bolt and then obviously ubolted to the axle it would probably be fine. id use a slightly larger allen bolt then the factory one. this would require drilling out each hole in the leaf pack wich is very difficult.
"body lift" is a missnomer and really has no business even being on a offroad vehicle.
a better option is to just collect leaves and experiment with different combinations to find one that works well.
fratis is offline   Reply With Quote
Old 11-26-2005, 07:00 PM   #7
murgg
thanks for all the replys.i already have 1"shackles so thats out. i was toyign with the idea of a 1" body lift, maybe in the future.
Old 11-26-2005, 09:07 PM   #8
jeffy
The problem with lift blocks is that they add unecessary stress to the U-bolts. Overtime, the U-bolts can stretch and leave room for the blocks to move. The blocks can crack or even fall out.
www.4BangerJP.com
Old 10-30-2010, 11:37 PM   #9
XJ-Tim
XJ-Tim's Avatar
Bastard packs ftw
XJ-Tim is offline   Reply With Quote
Old 10-31-2010, 12:03 AM   #10
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
In general, I don't recommend lift blocks on a YJ - but there are exceptions.
When I did my SOA, I installed a prototype MORE steering correction kit that Chris Overacker designed. IIRC, mine is either the second or third one ever made.
This kit came with a set of mini riser blocks which amount to nothing more than short spacer blocks that go between the perches and the bottom leaf, just like a standard type riser block does.
These mini riser blocks are used to help "center" the leaf springs between the drag link & tie rod of the MORE crossover steering kit - which is a good thing if your front leafs flex a lot.
Having the leafs centered, helps so that when they flex in either direction, they have less chance of contacting the steering links, especially while flexing & turning due to the inherant design of crossover steering & the MORE passenger side knuckle bracket.
So, in this case I HIGHLY recommend using a short (mine are ~7/16") mini riser block.
Notice in the first pic where the mini riser is & how short it is. No harm whatsoever.
In the second & third pics, you can see that my leaf is perfectly centered between the links (as it should be if set-up correctly).
Joe Dillard is offline   Reply With Quote
Old 10-31-2010, 12:21 AM   #11
Skwerly
1988 XJ Cherokee
haha .5" lift blocks wouldn't be so bad. especially if you aren't on the loud pedal a whole lot. even 1" i can't see hurting too much. 3 or more and yer into problems though.
Skwerly is offline   Reply With Quote
Old 10-31-2010, 01:11 PM   #12
RatherBeJeeping
you could use the zero rate AAL from ORD. a 1" lift blocks integrated to the spring pack
Add a Leafs, Zero Rate for 4x4 Suspensions from Offroad Design
John
95.5 YJ with "stuff"
RatherBeJeeping is offline   Reply With Quote
Old 10-31-2010, 01:43 PM   #13
jsawduste
Krawler
jsawduste's Avatar
2006 YJ Wrangler
Joe,
you used a short spacer to correct a potential problem. The OP is wanting to add a block for height.
I STRONGLY disagree with using a lift block (defined as something over .5 inch in height) in a front suspension.
In fact, most states have laws against front blocks of any type.
In a rear a block can be an acceptable way to add height. No more then an inch or so. Just understand that axle wrap WILL be increased.
jsawduste is offline   Reply With Quote
Old 10-31-2010, 01:55 PM   #14
fratis
fratis's Avatar
im gonna go out on a limb here and assume the op has made a decision by now.
Old 10-31-2010, 03:58 PM   #15
Joe Dillard
Yea, probably ~5 years ago.
Glock Forum
