Lift blocks - JeepForum.com
post #1 of 16 Old 01-20-2013, 06:27 PM Thread Starter
mykeyb01
Lift blocks
Someone suggested that blocks would be a good inexpensive way to lift my YJ? Recommendations? Advice?
mykeyb01 is offline
post #2 of 16 Old 01-20-2013, 06:30 PM
dillonjm
2013 WK
If you have a stock style suspension (springs under the axle) blocks will actually lower your Jeep, not lift it.
Regardless, on a Jeep blocks aren't the greatest idea.
Sounds like you got this advice from a pickup guy. Rear lift blocks are common in trucks but their suspension design is significantly different than a YJs.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 16 Old 01-20-2013, 06:38 PM
jason280
Yeah, go look at your Jeep and see how the springs attach to the axle assemblies, and you will see why blocks are a no-go.
jason280 is offline
post #4 of 16 Old 01-20-2013, 07:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like truck guy advice for sure. Probably suggest some extra shock towers for looks too.
Luck Favours The Prepared
Anticanman is offline
post #5 of 16 Old 01-20-2013, 09:19 PM
timatoe
timatoe's Avatar
For the remainder of the time you own your Jeep remember these words....... ANYTIME someone says it's a "good inexpensive or cheap way to lift..." Automatically throw that idea right out the window because it's likely a very bad idea.
timatoe is offline
post #6 of 16 Old 01-20-2013, 09:38 PM
tonymartin
Could look into a body lift though. Relatively inexpensive and is basically a bunch of blocks betwen the body and frame. May be what he was talking about.
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #7 of 16 Old 01-21-2013, 04:15 AM
Mark05059
Tonymartin:
They are talking about these -> http://www.autozone.com/autozone/acc...ier=540310_0_0_
In our configuration they lower.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 16 Old 01-21-2013, 05:14 AM
PastorBrian
1976 CJ5
I dont know about that. I did the s10 bastard pack lift. Good- check, inexpensive- check, lift- check. labor intensive? check
Cheap, easy, effective- pick any 2
PastorBrian is offline
post #9 of 16 Old 01-21-2013, 07:32 AM
jbolty
jbolty's Avatar
you can only pick two
jbolty is offline
post #10 of 16 Old 01-21-2013, 07:56 PM
timatoe
timatoe's Avatar
OK, but 99.999999% of the time when someone comes here with a, "my buddy said...." it's usually completely off base of what should be done. That's what I was getting at, not that it can't be done.
timatoe is offline
post #11 of 16 Old 01-21-2013, 08:35 PM Thread Starter
mykeyb01
Thanks!
mykeyb01 is offline
post #12 of 16 Old 01-21-2013, 08:52 PM
tonymartin
Originally Posted by Mark05059 View Post
Tonymartin:
Either way, a body lift would still be cheaper than a full suspension lift.
post #13 of 16 Old 01-21-2013, 09:00 PM
hypernoodle
Another option: taller springs.
hypernoodle is offline
post #14 of 16 Old 01-21-2013, 09:00 PM
Mark05059
I agree... however that wasnt what the OP was asking about and I was trying not to confuse him.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #15 of 16 Old 01-21-2013, 09:11 PM
Xpress
I second this. Pick two, the third will not apply.
All about that unibody life.
Xpress is offline
