-   -   Lift blocks (http://www.jeepforum.com/forum/f12/lift-blocks-1466583/)
mykeyb01 01-20-2013 07:27 PM
Lift blocks
Someone suggested that blocks would be a good inexpensive way to lift my YJ? Recommendations? Advice?
dillonjm 01-20-2013 07:30 PM
If you have a stock style suspension (springs under the axle) blocks will actually lower your Jeep, not lift it.
Regardless, on a Jeep blocks aren't the greatest idea.
Sounds like you got this advice from a pickup guy. Rear lift blocks are common in trucks but their suspension design is significantly different than a YJs.
jason280 01-20-2013 07:38 PM
Yeah, go look at your Jeep and see how the springs attach to the axle assemblies, and you will see why blocks are a no-go.
Anticanman 01-20-2013 08:13 PM
Sounds like truck guy advice for sure. Probably suggest some extra shock towers for looks too.
timatoe 01-20-2013 10:19 PM
For the remainder of the time you own your Jeep remember these words....... ANYTIME someone says it's a "good inexpensive or cheap way to lift..." Automatically throw that idea right out the window because it's likely a very bad idea. :cheers2:
tonymartin 01-20-2013 10:38 PM
Could look into a body lift though. Relatively inexpensive and is basically a bunch of blocks betwen the body and frame. May be what he was talking about.
Mark05059 01-21-2013 05:15 AM
Tonymartin:
They are talking about these -> http://www.autozone.com/autozone/acc...ier=540310_0_0_
In our configuration they lower.
PastorBrian 01-21-2013 06:14 AM
I dont know about that. I did the s10 bastard pack lift. Good- check, inexpensive- check, lift- check. labor intensive? check:2thumbsup:
Cheap, easy, effective- pick any 2:laugh:
jbolty 01-21-2013 08:32 AM
1 Attachment(s)
you can only pick two
timatoe 01-21-2013 08:56 PM
OK, but 99.999999% of the time when someone comes here with a, "my buddy said...." it's usually completely off base of what should be done. That's what I was getting at, not that it can't be done.
mykeyb01 01-21-2013 09:35 PM
Thanks!
tonymartin 01-21-2013 09:52 PM
Originally Posted by Mark05059 (Post 14825186)
Tonymartin:
Either way, a body lift would still be cheaper than a full suspension lift. :highfive:
hypernoodle 01-21-2013 10:00 PM
Another option: taller springs.
Mark05059 01-21-2013 10:00 PM
I agree... however that wasnt what the OP was asking about and I was trying not to confuse him.
Xpress 01-21-2013 10:11 PM
I second this. Pick two, the third will not apply.
The time now is 04:23 AM.
