Lift - JeepForum.com
post #1 of 4 Old 03-04-2002, 08:53 PM Thread Starter
kid991
Lift
Ok I got my lift an 31'but it feels like I got alot of vibrate.this right or am I just looking to hard for something to be wrong.I got the lift done At a spring shop so I know that it was not done halfA##.The Tires are M/T's .Do you think that's what it is
94 YJ I-6 ,3"lift 31'M/Ts
kid991 is offline
post #2 of 4 Old 03-04-2002, 09:54 PM
Keymaster
Keymaster's Avatar
Well, it depends on how much lift you got. I just installed a 3 inch suspension lift a couple of weeks ago. I run 31 inch All Terrains and mine rides smooth as silk. It may be the tires (I've never ran mud terrains so I'm not sure), but if your lift is 4 inches or over then it's possible you will need some more equipment to eliminate the vibration.
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Keymaster is offline
post #3 of 4 Old 03-05-2002, 09:23 AM
damonejeep
When do you feel the vibrations? I have MT's and they are smooth at speeds greater than 5 mph.
If your Jeep has vibrations at speeds greater than you might need a transmission drop. In your lift kit should have been several 1" long spacers. Those are to put inbetween the transfer case skid plate and the frame. This will lower the transfer case and should eliminate the vibs. However, you may have a worn U joint in your rear driveshaft. If so this is a easy and cheap fix.
In the future you will want to consider a slip yoke eliminator and cv driveshaft. These two items will allow you to raise the transfer case back up to its original position and realy increase your rigs strength.
Hope all of this helps.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #4 of 4 Old 03-05-2002, 08:58 PM Thread Starter
kid991
Thanks , My buddy thinks I am nuts.He can't feel a thing so I think its me.I just mite change my ujonts for peace of mind.
kid991 is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
