lift ??? - JeepForum.com
post #1 of 5 Old 05-03-2007, 06:29 PM Thread Starter
bryan-2kevo
lift ???
i have an 88 YJ, 4.2l, auto tranny. i have a 1" shackle lift, 3.5" superlift springs, and a transfer case lowering kit. i am running 35" tires on my d30 and 8.8 (4:10's). i also have a stock rear driveshaft, and a tj front shaft w/ cv joint.
i was wondering if i put on some 5" springs, instead of my 3.5" ones. will i have to lengthen my driveshafts???
i am prob going SYE this fall and prob SOA next year when i buy a new to me jeep!!!
my drive shaft angles look fine, not too steep, i am wanting to get a bit more lift for this summer. i hate getting cought up!!!!!!
thanks for all of your input
bryan-2kevo is offline
post #2 of 5 Old 05-03-2007, 06:42 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
you will probably need to put on an SYE kit with a CV driveshaft. go for BDS 5" lift, i got mine, they look unbelievable.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #3 of 5 Old 05-03-2007, 06:49 PM Thread Starter
bryan-2kevo
i was thinking that i would need one, but it is only 1 1/2" more of a lift. i wouldn't figure that would change the DS angles too much.
post #4 of 5 Old 05-03-2007, 07:15 PM
mean90yj
mean90yj's Avatar
my buddy has a 3.5" lift and has a t-case drop, and he may get 5" springs and needs an SYE kit, usually the rule of thumb is anything over 4" lift, it isn't a bad idea to do. You can get the CV rear driveshaft out of a new XJ and have it cut to length. Shouldn't be more then 50 for the shaft and 50 to have it modified.
~Enjoy>>>
mean90yj is offline
post #5 of 5 Old 05-03-2007, 08:10 PM Thread Starter
bryan-2kevo
i have found cv shafts that should fit depending on the height my lift. but i would rather go sye, cv shaft, and soa next winter when i buy a newer jeep.
i was just wondering if i could get any more lift for this summer.
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 07:46 AM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 06:59 PM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 11:03 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 10:04 AM
