which lift - JeepForum.com
post #1 of 7 Old 09-01-2014, 03:56 PM Thread Starter
jeepchic95
which lift
Looking to change up the jeep some...gonna keep running my 32x10.50......body or suspension lift? and Y? looking for about 2.5-3 inch of lift
jeepchic95 is offline
post #2 of 7 Old 09-01-2014, 04:06 PM
Chrisnvegas
Chrisnvegas's Avatar
Both.
2.5 inch OME lift for ride comfort and flex.
1/2 inch lift booms
1 inch body lift
That's 4 inches of comfortable riding lift. If you want less lift, leave off the 1" body lift.
4 inch lift spring will be arched more and more arch usually means a stiffer ride.
If you don't care about a stiff ride, 4" lift springs will be cheaper.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #3 of 7 Old 09-01-2014, 04:11 PM
Gealii
Agreed I run 2.5" leafs , 5/8 shackle, 1.25" body
It rides smooth drives straight and gives room for 33s flexed
For a dd this is probably the smartest way to lift
Gealii is offline
post #4 of 7 Old 09-01-2014, 04:59 PM
rctrav
My 93 2.5" OME springs 1" boom shackles and 1" body lift and 33" tires. Rides and flexes great.
rctrav is offline
post #5 of 7 Old 09-01-2014, 05:17 PM
mrmud4x4
I have a 3" superlift, procomp shocks, 1" daystar body lift on 33" BFG MT's. Needed to drop my tranny skid plate and get a Cardan drive shaft. I believe I added angle inserts on my rear axle also for correct pinion angle....I think 6.5 degree...not sure.
Not a stiff ride at all.....rides great!
(Maybe compared to my wife's highlander it is...)
Here it is with just the 3" suspension lift....
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #6 of 7 Old 09-01-2014, 06:15 PM
Chrisnvegas
Nice Jeeps RC and Mrmud.
My body lift is still sitting on the workbench. I just got the cast off my broken arm Tues. and it's still too weak for wrenching...
Henry Ford
post #7 of 7 Old 09-02-2014, 01:11 AM
mike134
My ride is... stiff... zero body roll at tight 40 mph curves...
mike134 is offline
