Lets see your mirror set up when your going door-less - JeepForum.com
post #1 of 29 Old 05-10-2013, 08:05 PM Thread Starter
BarryBum
Lets see your mirror set up when your running with your doors off.
BarryBum is offline
post #2 of 29 Old 05-10-2013, 09:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I put doors on when I go doorless
Luck Favours The Prepared
Anticanman is offline
post #3 of 29 Old 05-10-2013, 09:38 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Take that back, I do have a picture with no doors and safari mirrors
post #4 of 29 Old 05-10-2013, 09:54 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here's what I came up with;
http://www.jeepforum.com/forum/f12/m...95-yj-1397157/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 29 Old 05-10-2013, 10:04 PM
Firefyter-Emt
I have been thinking about using a spare set of windshield dash brackets to make mirror mounts. I have the old style CJ hand screws for my windshield and easily have enough thread to bolt a second set of brackets over the existing ones. If trimmed down so the top half is fitted around the top bolts, and some square stock welded to the top of the bracket over the bolt head's, and a set of CJ style mirrors bolted to the square tube maybe 8" out from the bracket. Then all I need to do is to remove the hand knob, place the mirror and bracket over the original bracket, and reattach them with the hand knob. Being trimmed around the top bolts will make it so that they can be mounted without removal of the torx bolts at the windshield, while keeping them from moving.
I will try to add some photos when I make them, but hopefully that gives somebody another idea.
Firefyter-Emt is offline
post #6 of 29 Old 05-10-2013, 10:07 PM
Idaho_Chad
Mirrors... What mirrors? When my doors come off, my mirrors come off.
Idaho_Chad is offline
post #7 of 29 Old 05-10-2013, 10:17 PM
Jeffro06
Jeffro06's Avatar
Mine too.....I have the rear view on the windshield, don't need anything else.....was the same way in the YJ.
Jeffro06 is offline
post #8 of 29 Old 05-11-2013, 07:49 AM
Rproject
1987 YJ Wrangler
Unfortunately, the OP lives in a state where they require at least one side mirror at all times.
Laybackman really did a nice job with his. I have safari mirrors for when I drop the windshield because I have to have at least one rear facing mirror. BTW, safari mirrors suck. They bounce all over the place and are basically there for looks.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #9 of 29 Old 05-11-2013, 08:44 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Here's what I've been using for years. They're cheap, easy, and fold completely into the cab, when you're offroading.
http://www.4x4xplor.com/doorless-mirror.html
The only thing I would add is star washers, to keep them from folding in on the freeway.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #10 of 29 Old 05-11-2013, 12:28 PM
Old4X
1990 CJ7
CJ style mirrors
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #11 of 29 Old 05-11-2013, 06:05 PM
YJames90
YJames90's Avatar
My 2.5 to 4.3 swap thread
YJames90 is offline
post #12 of 29 Old 05-11-2013, 07:28 PM
ejeeperguy
1982 CJ7
I used a set of cj hinges and mirrors from my other Jeep to put them on my YJ.
ejeeperguy is offline
post #13 of 29 Old 05-11-2013, 07:38 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
The one on me jeep replaces the one I'm holding. It was just a flimsy tube that I bent. It came with the mirror and I got the set at pep boys. I'm not the best welder but it will hold just fine for my needs. Just cut some 1" flat stock from Lowes in half and bent/drilled as needed.
Michaelgoesrawr is offline
post #14 of 29 Old 05-11-2013, 08:10 PM
zte87
GIVE IT THE ONION
zte87's Avatar
We welded some all thread to the bottom of a extra set of mirrors and bolt them to my upper door hing!
zte87 is offline
post #15 of 29 Old 05-11-2013, 09:52 PM
Jim93YJ
Jim93YJ's Avatar
I used the more modern Mopar sideview mirrors and adapted it to a Skid Row relocation bracket with a custom machined piece. I attached the detail drawing for the custom machined piece. I drilled a hole through the mirror arm and put a bolt right down the center. I kept the original spring in the mirror base so I could still tighten the bolt and get some preload from the spring to allow it to rotate but not move from wind resistance. The counterbore in the custom machined piece keeps the spring located.
93YJ 4.8L Vortec,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 33" BFG KM2 T/A's with MT Classic II Wheels, Herculined Inside, Electric Fan, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bushwacker Extended Flat Fender Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline
