Quantcast Lets see those Junkyard seats - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Lets see those Junkyard seats
Old 06-01-2007, 03:57 PM   #46
fatwreck
Yeah, they fit on the jeep sliders. The seats still function as normal.
fatwreck is offline   Reply With Quote
Old 06-02-2007, 11:08 AM   #47
newvances
seats similar to stock height and other info
I've been combing through the threads and I still have unanswered questions.
1. What makes (cavs, sunfire, mustangs,etc) and their years are a direct bolt in swap.
2. How close are they to the stock height?
3. What aftermarket seats are close to stock height ( I know Bestop is high).
Thanks for the help.
I have an 89 YJ.... by the way.
newvances is offline   Reply With Quote
Old 06-02-2007, 01:48 PM   #48
RAZORBILL
That's mine, give it back
RAZORBILL's Avatar
2011
1. Not sure of the exact years but when I was digging thru the junkyard it seemed all the mid to late 90's Cav's had the same seat set up. I think the 2000+ models might have changed. I didn't see any Mustang's to look at where I went.
2. I measured everything on the stock seat before I went to the yard. The Cav seats, and the Olds seats that I got, were all within a 1/2" of each other. I don't have any issues with getting in/out. I might still get a new steering wheel with a smaller diameter and get rid of the school bus wheel that is stock.
3. No knowledge of aftermarket stuff, too cheap!!!
The best advice I can give you is measure everything on your stock seat and then go the yard and poke around and see what you can find. I'm pretty sure all the GM cars took a 13 mm deep socket to free them up from the car.
Al
RAZORBILL is offline   Reply With Quote
Old 06-03-2007, 12:19 PM   #49
jeeping around
cavalier seats in yj
i did this yesterday they took me about 45 minutes to install ..they bolt right up on the stock jeep risers ....you do not even have to take the risers outa the jeep just take the 4 torx bolts off by sliding the seat back and forth to get to them and take the old seat off\out and reinstall the new one ...got these at the junk yard out of a 99 cavalier and also they had half price day at pick-your-part so i go then for 45 bucks out the door ...went home and used the carpet cleaner and wala here are some pics of them in my jeep ...they are mabe and inch or so higher then the stockers but then again the stock one are like flat ....also it feels like you might loos an inch on the drivers side when you have it slid all the way back ..but then again now you have some padding under your @ss...check out the pics
jeeping around is offline   Reply With Quote
Old 06-20-2007, 01:07 PM   #50
Songman
1990 FSJ Wagoneer
Originally Posted by dbikers
I saw this in another site....i have a 94 ranger and the seat sure is comfy...This is interesting but i would like to know how to get in the back with a top on it.....my kids climb in without the top on, but would they have to climb over the seat to get in...that would be a drag in the winter!!
Maybe try a seat from an extended cab Ranger. I have a 84 extended cab Ranger and the seats tilt forward for entry into the rear.
It does sound awfully convenient but I think a Jeep with a bench seat would feel kind weird to me.
1990 Jeep Grand Wagoneer
1990 Jeep J-10 Pickup
Songman is offline   Reply With Quote
Old 06-20-2007, 04:26 PM   #51
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
'03 rubicon seats
http://www.jeepforum.com/forum/f12/03-tj-seat-swap-questions-suggestions-425843/
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Glock Forum
