Lets play whats that sound? (with video!) - JeepForum.com
post #1 of 7 Old 02-08-2013, 06:21 PM Thread Starter
elnielsen
Sometimes when I start her up, there's a clacking, so loud I shut her off and restart and it doesn't happen. I caught it on video and it stopped by itself after 20-30 seconds.
Is the cause of this obvious? Should I do anything about it? I believe other sounds are more trouble. It is a 4L 6 cyl on a 94 YJ with 225K miles.
http://s300.beta.photobucket.com/use..._1256.mp4.html
elnielsen is offline
post #2 of 7 Old 02-08-2013, 06:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Linky no worky.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 7 Old 02-08-2013, 07:18 PM Thread Starter
elnielsen
Sorry, I made public.
post #4 of 7 Old 02-08-2013, 07:25 PM
timatoe
timatoe's Avatar
Sticky lifters?
timatoe is offline
post #5 of 7 Old 02-08-2013, 07:35 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Sounded like a lifter. How is your oil pressure at idle fully warmed up?
1. Dirty thinned out oil.
2. Sticking lifter.
3. Worn cam bearings causing low oil pressure.
4. Worn oil pump
If your oil pressure is ok (at least 25 psi idle fully warmed up engine)
Maybe you just have a sticky lifter. You can try adding a quart of ATF and run it easy for a couple hundred miles, then change the oil and filter. ATF has detergents that help free lifters and helps clean sludge out of the motor.
Some people try Marvel Mystery oil, some use Neutra, some use Gunk engine flush, ect, ect. These don't always work but might be worth a try. If none of these work, might be time to freshen the motor.
GET OFF MY LAWN!
Chrisnvegas is online now
post #6 of 7 Old 02-09-2013, 03:13 PM Thread Starter
elnielsen
Having just replaced the oil pressure sending unit, it runs at about 45 psi idling. I just did an oil change and it's very clean looking when I check the dipstick. I have run a quart of Mystery oil before. Currently I added a partial quart of Lucas as it has 225K miles on it.
I guess I won't worry about this much and worry more about the other sounds it's making coming from the bottom end.
post #7 of 7 Old 02-09-2013, 03:36 PM
Chrisnvegas
INFIDEL
Close to your next oil change, throw in a quart of dextron. Some old timers I know really swear by this for lifters. Maybe the last 500 miles of your oil change. Your oil pressure sounds good.
GET OFF MY LAWN!
