Lets play name that sound! Motor or Transmission?? - JeepForum.com
post #1 of 24 Old 05-29-2013, 10:32 PM Thread Starter
skyj
Ok my jeep started this rattle after a run over a mountain pass this weekend.
It only happens when the jeep is warmed up and around range 1500-2000 rpm, in all gears. oil pressure is 40psi on start up then after warm 10 to 15 psi at idle, sometimes drops to 0 but never knocks, when im cruising it stays at 20 psi.
Specs on Jeep: 1990 4.2 118,000 miles with 4.0 head , HEI, motorcraft 2100 carb, AX-15, NP231 SYE.
Back in '08 I installed the 4.0 head and checked the compression and all cylinders where in 130-140 range, and rod bearing clearance all were within spec. In '10 I replaced the transmission with a recent rebuilt AX-15 with external slave and new clutch with resurfaced flywheel, at the same time installed the SYE in the np231.I run an el cheapo Mr Gasket fuel pressure regulator set at 4psi, for the 2100 carb. Recently in january '13 I replaced the timing chain and gears, along with oil pump and fuel pump. I did not replace the dampner at the time although the TDC notch was way off on the dampner I set motor to TDC and put a paint mark on dampner to give it a new TDC mark timed it at 8*TDC. it has ran great with no problems since then.
I cant quit pinpoint the location of the sound but it seems to be back of motor bell housing area. in the recording I have it in 4th gear and am just cruising at 45 mph, I let off the gas and the rattle comes in at 2000 rpm, then I accelerate and sound goes away, let off gas again and rattle again, then acelerate, goes away and... well you get the picture.
click on black spot to hear recording \/\/\/
At first I think its a detonation problem should I retard my spark?? am I running lean?? havent checked plugs yet, they are new bosch platinums, I know, I know Or is it a pressure plate on the clutch chattering?? I cant tell Im confused Rod bearings bad??
build thread:
skyj is offline
post #2 of 24 Old 05-30-2013, 09:35 AM
zeus87gn
1987 YJ Wrangler
That's a vavletrain rattle
Bent rocker, broken tip on the valve, bent valve, broken valve spring, collapsing lifter, etc
Your crank dampener being separated is BAD
You need to replace it before it comes apart on you
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #3 of 24 Old 05-30-2013, 12:16 PM Thread Starter
skyj
Thanks zeus I was going to pull the valve cover and see if it was a bent push rod. And I will replace the dampner soon, real soon. Thanks!
build thread:
skyj is offline
post #4 of 24 Old 06-06-2013, 07:22 AM Thread Starter
skyj
Ok bringing this one back to the top.
I've been driving it around a little and the sound is definately coming from the front of the motor. I had the club listen to it last night at our meeting while it idled in the parking lot. Some guys think its a rod knock.
My buddy who is really good with sbc thinks its crank and rod bearings. I know I said earlier that it comes when load is applied in fact its the exact opposite The sound completely goes away when load is applied, until a certain rpm range making him think that when there is no pressure on the rod its allowing it to "slop".
I trust Zeus guess on Valve train but wanted to hear what others thought. Lower end of motor or top, or both?
I guess the next move is to pull the valve cover and see what I find there.
build thread:
skyj is offline
post #5 of 24 Old 06-06-2013, 07:13 PM
caoboy
I had a sound similar to that and it turned out to be a broken bracket on the windshield washer bottle. Probably not as loud though, and the only way I figured it out was by feeling on bolts by where the sound was coming from.
Is it all over the engine bay or can you pinpoint it?
http://www.harborfreight.com/mechani...ope-41966.html
That might help you out as well.
caoboy is offline
post #6 of 24 Old 06-06-2013, 08:09 PM
pasinbuy
Try taking a long screw driver and feel around the motor with the screw driver handle pressed to your ear. Try to find the sound that way until you can buy or borrow a stethoscope.
I used a long screwdriver to the ear for years.
pasinbuy is offline
post #7 of 24 Old 06-06-2013, 09:11 PM
Odie4az
I had the same noise on my 4 banger, all at the same rpms as you described.... Pulled valve cover, checked: rocker, springs, then changed out the lifters, checked rods, noise never went away.... I will check washer bottle but I'm now thinking maybe a chain noise... Just ordered the stethoscope and hope I can narrow it down, I did the screwdriver check but could not pin point it.... If I can figure it out I will let you know.. I just hope it's nothing that I have to pull the motor, I bought this a year ago and supposedly the engine was rebuilt with only 2,000 miles on it....
Odie4az is offline
post #8 of 24 Old 06-06-2013, 09:25 PM Thread Starter
skyj
Yeah I have that exact stethoscope I can hear it in the top end but when I hold it to block next to the #4 cylinder it definately gets louder. If I hold it to the exhaust manifold I hear it loud to. I just don't know when I will get around to tearing into it, or just run it and build a stroker from the 4.0 and spare 4.2 I have. If its just crank/ rod bearings I can just get new bearings and lengthen its life or see if its valve train issues and hope its an easy fix without removing the head.
build thread:
skyj is offline
post #9 of 24 Old 06-07-2013, 12:21 AM
greyarea
That is what my 4.2 sounded like just before it wore through the aluminum cam sprocket teeth after the nylon went away.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #10 of 24 Old 06-07-2013, 06:02 AM Thread Starter
skyj
I just replaced my timing set two months ago.
build thread:
skyj is offline
post #11 of 24 Old 06-07-2013, 10:50 AM Thread Starter
skyj
Sound almost completly goes away when I disconnect the vacuum advance. What's the cure to this problem?
build thread:
skyj is offline
post #12 of 24 Old 06-07-2013, 11:04 AM
rykemc
Could it be detonation?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #13 of 24 Old 06-07-2013, 11:06 AM
rykemc
Have you pulled that plug and compare it to the others? Maybe even do a compression test on that cylinder
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #14 of 24 Old 06-07-2013, 11:29 AM Thread Starter
skyj
The sound didn't change when I pulled the plug in that cylinder infact I got a little lifter noise when I pull the plugs on the cylinders. I still need to do a compression test. I did one years ago when I swapped on the 4.0 head and they were all around 130-140 psi so I figured good to go.
I'm thinking I will retard the spark and turn up the idle on the carb and take her for a ride.
build thread:
skyj is offline
post #15 of 24 Old 06-07-2013, 03:24 PM Thread Starter
skyj
Ok its definitely the vacuum advance causing this..... Dunno why but it is,I assume its a bit of predetonation...ok maybe a lot of predetonation. How do I fix this?? when I installed this HEI years ago I followed a thread I found on wrangler forum and simply just followed what he did. It's worked for years so don't know why it had reared its head now.
My only thought is maybe I got a bad batch of gas with a lot of Ethanol in it?? No matter how much I retard the spark I can't get it to stop with the vacuum advance hooked up. If I advance it without it hooked up it won't do it... So where do I go from here?? It runs best at 8* btdc, but knocks like crazy with the vacuum advance...
build thread:
skyj is offline
