let's say you've got about $1300 to spend... - JeepForum.com
post #1 of 6 Old 10-08-2002, 11:04 AM Thread Starter
ace3
and you need:
4" lift kit
31" or 33" tires
black Rockcrawler wheels
what would you get?
4wheelparts.com has a Pro Comp package with the wheels/tires for about that price. Should I look into a different lift setup instead?
i'm not going to be doing a lot of off-roading or anything, but will do it every once in a while.
thoughts?
HELP A NEWBIE!
ace3 is offline
post #2 of 6 Old 10-08-2002, 11:23 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
To keep it simple ..
31" tires do not require 4" of lift .. the 33" tires do require 4" of lift
2.5" of lift will allow 31" tires, or add some fender trimming to allow 33" tires to fit
What's wrong with the stock rims? I ran stock rims with 33" tires on 4" of lift .. no problems. The lighter aluminum rims don't take as much power away from the motor as steel rims do.
As far as havin' $1300 to spend .. I would put more power into the engine, change the gears, cut the body and slap the biggest rubber I can on the ends of the axles .. then take the money left over and build a garage
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 6 Old 10-08-2002, 12:57 PM Thread Starter
ace3
okay, okay....
i NEED to redo the lift that it has on it ... it currently has these 6" shackes on it. I want to lift it correctly, and then put 33's on it (forget about hte 31's) with the rockcrawler wheels. (because i like the looks of 'em).
i'm basically asking if that package deal is worth the price, or if I should buy wheels/tires/suspension separately somewhere else. AND, if I should look into something other than ProComp, still trying to stay under budget.
sorry for the complex question.... i can't seem to find any advice on this subject here.
thanks, everyone...
ace3 is offline
post #4 of 6 Old 10-08-2002, 03:51 PM
NaeKid
NaeKid's Avatar
Ahh .. Ooohh .. well .. then .. Hmm ..
If it was me I would choose something other than the Procomp springs .. just because everyone who has that spring set complains about it .. I would hate for you to start on that band-wagon as well.
I am fairly happy with my SuperLift (spring model is listed on my homepage) kit .. when I first did the lift, my flex wasn't great, but its getting better as the springs have a chance to work in. I am running the springs with no sway-bars or trackbars with no ill-effects on street or trail.
Others swear by the ride quality of the OME springs .. and the RE Springs have also gained huge acceptance among the Jeeper world.
Ultimately, the decision is yours .. but if I was you, wanting to remove the too-long shackles I would look at putting the Bushwacker flares on and using the OME springs to fit the 33" tires ..
Silver
NaeKid is offline
post #5 of 6 Old 10-09-2002, 05:07 PM
CB89XJ
I agree w/ Naekid, I'd stay away from ProCrap. I had their 3" lift on my XJ, is it's junk. There are many better kits out there for the money.
If you have welding and fabbing skills, what about a spring-over? You will need an SYE, I don't know if you have one yet, but you'd prolly need one anyway w/ a 4" lift.
Look into some MT/R's for tires. They are awesome, and will be my next set. What kind of wheeling do you do or plan on doing? I hear they $uck in the mud, but awesome on rocks. I have ProComp MT's on my YJ, and they are decent too. They are siped for wet weather, and they are good offroad too.
HTH
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
post #6 of 6 Old 10-10-2002, 11:18 AM
YJHoller
YJHoller's Avatar
1300 Dollars
I really have nothing to add of value. I just wanted to say I bought my Jeep for $1300. So thats what I would do.
Thats my half a cent.
Dan
1988 Wrangler Laredo
1991 4.0L HighOutput, 5-speed, Cherokee Seats, K&N Air Filter, 2" add-a-leaf, 31x10.5, rear locker, Ramsey winch
YJHoller is offline
1300 dollars to spend on a lift kit and tires 1997jeeptj TJ Wrangler Technical Forum 17 02-17-2009 04:18 PM
1100-1300 rpm rattle pipelineaudio TJ Wrangler Technical Forum 0 06-24-2008 02:40 AM
Challenge-$1300, What would you do? rbrough1010 JK Wrangler Technical Forum 3 05-10-2007 03:21 AM
Best $1300 I ever spent! OneCleanYj YJ Wrangler Technical Forum 5 05-06-2007 10:28 PM
Talk me out of spending 1300 chucks mckaax TJ Wrangler Technical Forum 39 01-19-2007 12:27 PM
