Quantcast Length Envy: A build thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Length Envy: A build thread
Poison Spyder BFH Rear BumpersFront and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yo
Old 11-21-2008, 12:35 AM   #76
teejmcd
keep the roll bar and put a scrambler top on it ahah
1994 yj. lifted 4 inches locked, loaded, and armored!
Member of Great Lakes Jeep Thing
and supporting jeeps gone wild
teejmcd is offline   Reply With Quote
Old 11-21-2008, 12:57 AM   #77
dukegnarley
the fender flares will most likely be extended tj flares. I'm not sure what I'm going to do with the cage or top yet. If i go with the unlimited top, i will need to get the unlimited cage or build my own. I've already done a preliminary search around the area for an unlimited cage, but there are none to be had. If i could find one it would most likely be expensive. The other option is to modify the cage i have, but then I'd have to make a custom top because the bars between the main hoop and the windshield are too far apart to use a tj style top.
I wouldn't mind a scrambler hardtop, but that would mean getting a pair of hard doors (which i hate) to make it look good.
Since my budget is already stretched a bit thin, I'm probably going to go with whatever option is the cheapest.
Unlimited Length YJ "Sasquatch"
Build Thread
Renix 4.0
AW4 swap with awshifter = DONE
custom console
flatdash
dukegnarley is offline   Reply With Quote
Old 11-21-2008, 07:48 PM   #78
ilikedirt
wow! this thing is going to be sick!
soon to be xj or zj
"We can't expect the American people to jump from capitalism to Communism but we can assist their leaders by giving them small amounts of Socialism until they awaken one day to find out they have Communism." -Nikita Khrushchev
ilikedirt is offline   Reply With Quote
Old 11-24-2008, 09:09 AM   #79
95meyers
subscribing - great build and original idea - wish i had a shop to due all my building
95meyers is offline   Reply With Quote
Old 11-24-2008, 02:07 PM   #80
dukegnarley
Thanks, I'm hoping to have the frame rails done within the next couple of days before i go home for Thanksgiving.
Build Thread
Renix 4.0
custom console
flatdash
Old 11-24-2008, 02:13 PM   #81
SteveJcoYJ
i'm trying to decide between painting mine that krylon khaki or olive drab, probably figure it out at the store
what are the plans motor/ drivetrain wise, keepin the 4.0 in it ?
91ish YJ
Originally Posted by sportsdevil333 View Post
ive had girlfriends before and been laid numerous times I just didnt know how to go about with this particular situation since ive never seen a girl do what she did
SteveJcoYJ is offline   Reply With Quote
Old 11-24-2008, 02:45 PM   #82
dukegnarley
Yeah I'm keeping my Renix 4.0 until it dies... which might not be too far away. After that i'm going to swap in a newer 4.0 or maybe a small diesel. It might be the lighting in power tech, but that khaki has a bit of a green tint to it.
Build Thread
Renix 4.0
custom console
flatdash
Old 11-25-2008, 11:17 AM   #83
pbell75
great job so far
pbell75 is offline   Reply With Quote
Old 11-25-2008, 12:15 PM   #84
Cbaughn
Any pic updates? I seriously get pumped when I see another post has been added to this thread.... Ha.
Cbaughn is offline   Reply With Quote
Old 11-25-2008, 09:35 PM   #85
dukegnarley
update
Ok so i got the frame mostly back together.
i started by making a cardboard template of the shape i wanted to make.
I then got it all layed out on the 4"x3" .25 wall tubing.
then cut them out. Once i had the wedges cut off of the ends, the sides bowed out quite a bit.
I ground the edges down a little since the frame material is only 1/8" thick. I then test fit the pieces in between the frame rails. The back of one of the tabs had to be cut off to clear the fuel tank cross member.
I used the angle finder to get the piece in at about the right angle and tack welded it in. I had to use a C-clamp to hold the sides of the tube up to the frame since it had bowed out.
I repeated this process for the other side.
to get the rear part of the frame up to match, i used a floor jack with a 2X4 to lift the rear up a little bit. it only moved about 1/4" until the frame started coming up off of the jack stands. i moved it the rest of the way with a C-clamp.
I then tacked it up and repeated for the other side.
Then i welded them up. They're only about 1/2 way welded right now, i need to jack the body off of the frame a little to get to everything, but that will have to wait until after Thanksgiving. Some of the welds turned out pretty well while some weren't so great. I've got my welder cranked up as far as she'll go, so we'll see how it goes. I'll grind the bad ones off and do it again.
Another thing i'm going to have to contend with is the fuel filler. I was just going to fill the tj filler hole in the crusher corner and cut one out in the stock location, but then i realized that the light holes in these corners are closer together than stock.
the circle is where the light goes. Looks pretty bad I know. So, I'm trying to decide what to do. I might try to get the TJ filler to work, or i might just move the stock filler farther inwards to match the lights.
Build Thread
Renix 4.0
custom console
flatdash
Old 11-25-2008, 09:40 PM   #86
Mean Max
Mean Max's Avatar
I vote for the TJ filler!
I've been wanting to relocate mine there for some time now!
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 11-25-2008, 09:44 PM   #87
spyder6
Just violated my Parole
spyder6's Avatar
great work on the frame
all i can say is, you need to make more progress because i like looking at all the pictures
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 11-25-2008, 10:32 PM   #88
chocflip201
something that might help a little is more shielding gas.. (the brown dust around your welds indicates not enough gas...
chocflip201 is offline   Reply With Quote
Old 11-25-2008, 10:50 PM   #89
dukegnarley
Thanks, I'll give that a shot.
Build Thread
Renix 4.0
custom console
flatdash
Old 11-25-2008, 11:27 PM   #90
SteveJcoYJ
the pictures are the only reason i was able to read 6 pages
91ish YJ
Glock Forum
