Led turn signal bulb - JeepForum.com
post #1 of 15 Old 01-24-2016, 03:44 PM Thread Starter
bck4more
1987 YJ Wrangler
Ok I've bought 3 different bulbs now but have same issue every time. Im just wanting to replace my front turn signal bulb with LED but they don't flash. I don't have side marker lights and on the rear I have the flush style LED lights. Anyone know what is causing this?
1987 4.2 automatic, 33" Pro Comp, 2100MC, nuttered, SOA, SYE,TW driveshaft
bck4more is offline
post #2 of 15 Old 01-24-2016, 03:52 PM
xjrjrx
With mine on a 94 I added side marker led bulbs and a flasher that has an extra ground wire on it and got them to all work there is a floating ground of sorts that switches the front and side marker lights when you use your turn signal your lights are flashing but extremely fast try the flasher relay and adding the flare lights
xjrjrx is offline
post #3 of 15 Old 01-25-2016, 04:01 PM
metalhead
2011 WK
This is what you need. Got it from amazon.
1994 YJ (no longer own
2000 Grand Cherokee WJ (no longer own)
2011 Grand Cherokee WK2
metalhead is offline
post #4 of 15 Old 01-25-2016, 04:34 PM
fishadventure
I can't see what year he has on the app but that is likely the correct answer for him.
Amazon has a bunch of them. I have one on the kitchen counter right now for my CB400F that's got LED rear blinks/brake/tail inherited from an older Ducati Monster.
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
post #5 of 15 Old 01-25-2016, 04:51 PM
xjrjrx
that's the one
xjrjrx is offline
post #6 of 15 Old 01-25-2016, 05:03 PM
Drednot
The LED bulbs don't pull enough power to heat up the flasher's bi-metallic switch that makes the flasher flash.
There are electronic flashers made that overcome that. Like the one pictured above.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #7 of 15 Old 01-25-2016, 08:57 PM
Bailey_S1007
You can buy the electronic flasher at a autoparts store. I just bought some get the EL-12 flasher
Bailey_S1007 is offline
post #8 of 15 Old 01-25-2016, 09:23 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
That's what I got. Autozone and Napa sell them. They don't have a ground wire, but work with LED's.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #9 of 15 Old 01-25-2016, 09:43 PM
xjrjrx
They work with leds but they do not work when you run front(grill and side marker) and rear leds you might be able to have them work without your headlights on but once they are on with that flasher they will not work I had that problem along with dozens of other guys here putting leds front and rear
xjrjrx is offline
post #10 of 15 Old 01-25-2016, 11:40 PM
Mr.B
Mr.B's Avatar
That sounds odd. The EL-12 is just a simple mechanical flasher, as far as I know. It should work no matter what you have plugged into it. But I only have rear LED's, so I never had that problem.
Ham license:
Everyone is Welcome
Mr.B is offline
post #11 of 15 Old 01-26-2016, 01:43 AM
timatoe
timatoe's Avatar
Hmm, I have that same EL-12 flasher and my side marker LED's up front and the rear tail/stop/turn signals all work, even when the headlights are on.
timatoe is offline
post #12 of 15 Old 01-26-2016, 07:29 AM
xjrjrx
I had that one in mine when I swapped the rear to LEDs and it worked then when I switched the grille lights it went hyper flash on me and looked like it was solid then I added side marker LEDs and the flasher with a ground and they all worked and I have read many other threads from others with the same problem maybe yours is a little different then the others but some flashers worked for some while they didn't for others those YJ's are weird
xjrjrx is offline
post #13 of 15 Old 01-26-2016, 11:02 AM
timatoe
timatoe's Avatar
One thing is for sure, none of them are the same.
timatoe is offline
post #14 of 15 Old 01-31-2016, 09:02 AM Thread Starter
bck4more
1987 YJ Wrangler
Well installed the Eflasher like the one in the OP post and they work till you turn park lamps on then they no longer flash.
bck4more is offline
post #15 of 15 Old 01-31-2016, 08:30 PM
Drednot
Did you ground that little wire?
Did you run ground wires from the rear housings to the front of the jeep/battery, or are you relying on the tub?
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
