led tailight help (already searched) - JeepForum.com
post #1 of 14 Old 01-17-2010, 06:01 PM Thread Starter
gottkts
I have searched the forums and cant find what i am looking for. I installed a set of the led trailer lights on my yj and cant get them to work properly. When i turn the lights on only one tailight lights up and both blinker lights come on on the dash and stay lit. When i hit the brakes they come on fine and the hazards work fine but have no blinker what so ever and only the one running light. I HAVE THE EL 12 FLASHER BUT STILL NOTHING DIFFFERENT. Does anyone have wiring diagram of the tailights. I went by what stu had on his site at stuoffroad because all of the colors were the same but maybe something has changed. I am trying to get everything working properly before tearing down for paint thanks for the help
gottkts is offline
post #2 of 14 Old 01-17-2010, 06:25 PM
jagarcia82
1987 YJ Wrangler
Double check the connection on the taillight thats not coming on. Unless you have a short in your wires before it gets to your rear end it should work. I twisted wires together till I was certain where everything went, the electric flasher was a headache for me.
You might have a bad electric flasher because my flashers wouldn't blink till I got it cause it wasnt enough voltage to trip the relay? Hope that helps I'm no pro but just going by my mistakes.
jagarcia82 is offline
post #3 of 14 Old 01-17-2010, 06:30 PM Thread Starter
gottkts
the light comes on when i press the brake and when flashers are on. It just turns off as soon as i put the parking lights on and as stated before have no blinkers at all on either light. it is confusing and time consuming thanks for the help
gottkts is offline
post #4 of 14 Old 01-17-2010, 06:35 PM
Robyjuk
1987 YJ Wrangler
you need to raise the resistance in the circuit to trigger the flasher unit, its a common problem we get over here when people convert US cars to UK lighting regs, you need to find a resistor ( not sure what ohm) and have it connected across the + feed from the lamp and the earth so its wired in paralell.
Robyjuk is offline
post #5 of 14 Old 01-17-2010, 06:35 PM
dodger889
Check you ground for the light. Oh most of the leds White is the ground.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 14 Old 01-17-2010, 10:51 PM
timatoe
timatoe's Avatar
X's 2 sounds like a ground issue to me. The stock lights are grounded to the tub, if you didn't run a specific ground wire for the new lights they're not grounded.
BTW, the EL-12 (as I'm sure you know) corrects the two issues previously stated about tripping the flasher etc...
timatoe is online now
post #7 of 14 Old 01-17-2010, 11:04 PM
T-Mack
i agree check the ground then throw a resistor on em, when i did mine i didn't use em when i would hit my blikers they would blink crazy fast to where u couldnt see them blink just looked like a steady light, got a resistor for each side and problem solved
T-Mack is offline
post #8 of 14 Old 01-17-2010, 11:05 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
The best way around the resistance type flasher is to simply replace it with an electronic base flasher. Plug and play.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #9 of 14 Old 01-17-2010, 11:09 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
OP already has the EL-12 flasher.
My opinion is that he has grounding issues, which was already suggested by dodger889, timatoe & T-Mack so I was just keeping my mouth shut on this one.
OOPS!
Max
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #10 of 14 Old 01-18-2010, 07:10 AM Thread Starter
gottkts
I have both lights grounded with the white wire. I am going to try swapping the other two wires tonight
gottkts is offline
post #11 of 14 Old 01-18-2010, 08:10 AM
idaholtby
Well if the grounds are good, then is it possible that the EL-12 was installed in the hazzard slot rather than the turn? Or did you swap out both with the El-12?
idaholtby is offline
post #12 of 14 Old 01-18-2010, 10:24 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Most all of those trailer light pigtails have a 3 wires.
RED = stop, brake, & turn
BLACK = parking lights
WHITE = ground for both bulb circuits
Max
Mean Max is offline
post #13 of 14 Old 01-18-2010, 10:33 AM
ScottyDoe
2015 JK Wrangler
yeah I agree with the rest of the guys that its a grounding issue, but on mine, i got Grote leds, and they work perfect, i didnt even have to install a resistor or anything, they blink at the normal rate it should
ScottyDoe is offline
post #14 of 14 Old 01-18-2010, 06:18 PM Thread Starter
gottkts
Thanks for all of the input guys, figured out the problem. I guess i moved the wire connector around too much and broke the solder connection but it was under shrink wrap so i couldnt see it. After reattaching everything works great
gottkts is offline
2.5 Header.. searched and searched SimplyTron YJ Wrangler Technical Forum 4 11-15-2009 01:33 AM
LED Tailight question njsjeep TJ Wrangler Technical Forum 6 01-16-2009 01:14 PM
busted tailight question kaybone TJ Wrangler Technical Forum 2 03-06-2008 11:48 AM
Replacement Tailight housing's? FXSTCHEWY TJ Wrangler Technical Forum 2 04-06-2005 11:18 PM
Need some tailight help Special Ed YJ Wrangler Technical Forum 5 03-10-2004 10:03 AM
