led tail lights - JeepForum.com
post #1 of 17 Old 01-05-2012, 09:30 PM Thread Starter
y87j
1987 YJ Wrangler
led tail lights
I am going to be swapping my stock yj tail lights to flush mount leds ..I wanna know what people use to cut the hole... and is their any post of just pictures of it installed..would like to see diagrams how its all wired? Thankyou
y87j is offline
post #2 of 17 Old 01-05-2012, 09:32 PM
dillonjm
2013 WK
The appropriate sized hole saw would probably work well.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 17 Old 01-05-2012, 10:01 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Try searching for a post by Max on this very subject. Up to his normal standard of excellence.
I just built a rig for a guy, and cheated and used my plasma cutter on his rig. I installed corner guards so it wasn't an issue. Would have used the hole saw, but couldn't find the damn thing, so they met Mr Hypertherm instead
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 17 Old 01-05-2012, 10:03 PM
Xpress
What about installing these flush mount:
http://www.superbrightleds.com/cgi-b...-r16w18-lp.htm
Any ideas for a clean fit? I'm guessing that i'll have to buy a dremel to make them look good
All about that unibody life.
Xpress is offline
post #5 of 17 Old 01-05-2012, 10:09 PM
leftlanetruckin
XJ on 37's
Too expensive IMO.
The 4" round ones look better, and are cheaper at any truckstop. Hell I got some new ones for my big trailer for $9.99 each at a Pilot a while ago.....
Martin
post #6 of 17 Old 01-05-2012, 11:09 PM
Xpress
i'm not a fan of the round ones, i like mine to look like a Wrangler, not a CJ
Xpress is offline
post #7 of 17 Old 01-05-2012, 11:31 PM
firefighter315
I taped the area off with masking tape, drew the template I needed, and cut the hole with a jig saw and a good metal blade. Cut like butter and left a very clean edge.
My YJ Build Thread
firefighter315 is offline
post #8 of 17 Old 01-06-2012, 12:54 AM
SnowdogMarc
I used a hole saw and jig saw to cut mine in. Didn't like the factory style ones or the price and the round ones were just too much like everyone else so I went with oval high output.
Found out about 2 months later that I could have got the backups in the oval as well. Oh well they are stupid bright and are like having headlights in the back.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #9 of 17 Old 01-06-2012, 06:34 AM
uhohthe50
I bought these: http://www.harborfreight.com/4-inch-...ght-93263.html
I used a hole saw to cut them out. I'm not positive, but I think it was 4 1/2 ".
Some pics are located on the first page of my build thread if you want to see what the lights look like mounted:
http://www.jeepforum.com/forum/f12/m...90-yj-1291174/
uhohthe50 is offline
post #10 of 17 Old 01-06-2012, 11:28 AM
timatoe
timatoe's Avatar
This is exactly what I did, very smooth and easy.
I agree with Martin, the round flush mounts can be had super cheap at any truck stop. I used to have (well still do in the garage) the ones from Harbor Freight, I got them on sale for like $8 each and they were OK. I replaced them with some 43 LED units from a truck stop for about $12 each and they're night and day different with the amount and brightness of the light.
Keep in mind you WILL need something for a tag light and reverse lights. Both can be done pretty cheap.
Oh, and yes 4 1/2" is the right size if you're gonna do the hole saw, they're about $23 for the saw.
timatoe is offline
post #11 of 17 Old 01-07-2012, 07:26 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Here is what mine looks like at the moment. LED tail light install with LED BU lights. Gas filler move to the TJ location. Tire carrier delete...moved the spare to where the rear seat was using a custom tire holder I fabbed up.
I used duck tape then cut the hole with my el cheapo jig saw with a metal cutting blade.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #12 of 17 Old 01-08-2012, 03:03 AM
SandyMushYJ
Found these while looking at different 4-inch rounds. Nineteen diodes each and only $9, though grommet sold seperately:
http://www.northerntool.com/shop/too...1266_200391266
'95 YJ, 2.5L, AX-5, RC 2.5", 31" Pro Comp MT's
SandyMushYJ is offline
post #13 of 17 Old 11-05-2012, 05:42 AM
Deezz22
since so many people go with the red round ones, i went with the clear oval ones. Teh reverse lights are the smal oval ones next to the tails. AND these are SURFACE mounts lights, so i didnt have to cut holes in the body. They are held in with screws and not a groumet. And i put a 3rd brake light across the bottom.
Uploaded at Picoodle.com
1990 Jeep Wrangler YJ 4" Leaf spring lift; 33" Cooper Discover; Dick Cepek DC IIs; "modified" stock bumper
2012 Wrangler JK Gecko Green 3.25" Rustys Lift, 35" Mickey Thompson MTZ, 20" Fuel Octane Wheels, Stubby Bumper caps
Deezz22 is offline
post #14 of 17 Old 11-05-2012, 09:02 AM
kjg26
kjg26's Avatar
What lights did you use for the reverse?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #15 of 17 Old 11-05-2012, 10:17 AM
Deezz22
my reverse lights are these...
http://www.ebay.com/itm/LED-Light-2-...b#ht_971wt_679
Deezz22 is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 06:33 AM
Just installed LED Tail lights but reverse lights come on with brake lights... Yarney05 TJ Wrangler Technical Forum 19 04-22-2011 12:13 PM
tail lights not working correctly, passesnger side tail is dim. kbarwall TJ Wrangler Technical Forum 2 08-19-2008 10:22 PM
Which LED's are best for my recessed tail lights? How did you do backup lights?Pics? quitelifted TJ Wrangler Technical Forum 10 02-04-2007 03:46 PM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 09:18 PM
