LED Side and Parking Lights??? - JeepForum.com
post #1 of 34 Old 01-18-2013, 11:11 PM Thread Starter
Stingray427
I did the dash LED's mod and think it is great. I also have the plug and play LED tail lights with the right flasher fuse for LED's and everything is working great!
My question is, can I just add LED bulbs to the front side marker lights (in the flares) and the parking lamps in the grille?
Stingray427 is offline
post #2 of 34 Old 01-18-2013, 11:29 PM
Dano63
I did my LED dash light swap a month or so ago, also changed my tail lights and back-up lights to LEDs. 1157 and 1156s in LED. 194s in LED for the dash. Same for the side marker lights. 194 bulbs in LED. The front lights are 1157 in LED. They do not ground on the body like my tail lights, so I had to use a resistor for the front lights, in line, else it showed as a 'no light' condition and they wouldn't flash. Very cool look. Love it.
Dano63 is offline
post #3 of 34 Old 01-18-2013, 11:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
https://youtu.be/DhpypjhpPU8
Luck Favours The Prepared
Anticanman is offline
post #4 of 34 Old 01-18-2013, 11:56 PM
SeanB95YJ
you CAN just install LED bulbs, but for the front turn signals IMO they don't have the "oomph" an LED should have because if being filtered through a lens not designed for an LED lamp.
So far that I've found, there isn't a direct replacement LED unit available for either the markers OR the turn signals...the side markers are an odd size and not available (yet, that I've found) as a direct replacement, or even reasonably close. once I ditch the stock flares, I plan to put an LED lamp for the marker though with a little bit of work (if you're not afraid to cut sheetmetal)
but for the sugnals, I found THESE UNITS from superbright are really nice and look like they could have come from the factory that way. You have to cut the opening a little bigger, and they're a grommet mount. real simple to install.
Put them on mine this fall:
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 34 Old 01-19-2013, 07:10 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I love the LED turn signals. Ridiculously bright.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #6 of 34 Old 01-19-2013, 08:58 AM
Xpress
To answer your question, if you bought an Electronic style flasher, then yes you can just swap in any turn signal bulb, LED or incandescent, without issue. The electronic flasher relay doesn't use resistance like the older units do.
All about that unibody life.
Xpress is offline
post #7 of 34 Old 01-19-2013, 09:11 AM
jay-h
When you look at LED replacements for incandescent bulbs, pay attention to the direction of the light. There are different kinds. Some for example send light out the 'top' of the bulb, which won't work so good for sideways mounted bulbs.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #8 of 34 Old 01-19-2013, 12:11 PM Thread Starter
Stingray427
Yes I have an electronic flasher relay- so I should be all set.
post #9 of 34 Old 01-19-2013, 12:14 PM Thread Starter
Stingray427
I was wondering about that. I went to SuperBright LED's.com and saw that for example when you search 1157 replacement bulbs a whole slew of choices come up.
Which bulbs do you recommend for the front and side bulbs to spread the light the best?
post #10 of 34 Old 01-19-2013, 01:31 PM
jay-h
http://www.superbrightleds.com/cat/t...r,1157,21,195:
the first few on this page look suitable if your tailights are like mine, but I don't have personal experience with that product.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #11 of 34 Old 01-19-2013, 02:16 PM Thread Starter
Stingray427
What about these for the front grille lights?
http://www.superbrightleds.com/morei...ed-spider/818/
post #12 of 34 Old 01-19-2013, 04:59 PM
NHfireLJ
NHfireLJ's Avatar
Did you cut the grill to fit those?
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #13 of 34 Old 01-19-2013, 05:44 PM
SeanB95YJ
I'm not the one you asked, but I have the same lights. Yes, the grill needs to be cut. more or less to the edge of the bevel area, These are a grommet mount, so once you've got your hole cut, they just sort of snap in place
swap/build thread:
post #14 of 34 Old 01-26-2013, 03:06 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
+1. Had to cut the opening flat.
-Matt
White '94 YJ Sport
UltimatE is offline
post #15 of 34 Old 01-26-2013, 05:43 PM
Wranglin4Life
Was there any kind of additional wiring needed to be done or are they plug and play?
Wranglin4Life is offline
