Led side marker/turn signals - JeepForum.com
 2Likes
  • 2 Post By xjrjrx
post #1 of 5 Old 05-23-2016, 02:09 PM Thread Starter
xjrjrx
Recently put on some tube fenders and went to install the 3/4 lights I got with 2 wires and they either work with the headlights on wired one way or no headlights the other way do I need a 3 wire light for them to work I see poison spyder has some I need them to work with my headlights on or off
xjrjrx is online now
post #2 of 5 Old 05-23-2016, 02:10 PM Thread Starter
xjrjrx
And I did have led 194 bulbs in before I tried to swap and they worked
post #3 of 5 Old 05-23-2016, 09:58 PM
timatoe
timatoe's Avatar
I'd have to look and see how I wired mine, but they are also 2 wire 3/4" LED's. Basically mine are on when the lights are on and switch off when the signal fires instead of staying on and then blinking brighter etc.
timatoe is offline
post #4 of 5 Old 05-23-2016, 10:48 PM Thread Starter
xjrjrx
It's weird so if I wire it one way it only works with the headlights off and the parking light doesn't work if I wire it the other way it only works with the headlights on and the parking light does work I'm thinking I need something that has 3 wires to work with the headlights both on and off I saw poison spyder has ones that wire to parking light turn signal and grounds I think I just need those
post #5 of 5 Old 06-21-2016, 11:07 AM Thread Starter
xjrjrx
Got my blinkers figured out a 3 wire up front dos the trick and I decided to keep the 2 wire light and hid it in the wheel wells
shaggyjim and bruinjeeper like this.
