LED Replacement dash lights - JeepForum.com
post #1 of 20 Old 09-02-2008, 04:03 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I'm getting ready to upgrade my dash lights to LED's, since I cannot seen them at all during the day.
Which bulbs are 194? There are 2 different sizes for the gauge lights... A smaller bulb for the turn signal + warning lights, and larger ones for the rest of the gauges. What is the other model number needed to replace everything?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #2 of 20 Old 09-02-2008, 04:29 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
*If there are any errors, please let me know and I will correct it*
Just for future reference, here are the model numbers that came up for the Wrangler's dash:
194 -- Used for speedometer, tachometer, and center gauges. Also listed as PC194 (bulb w/ plastic base)
74 -- Looks just like the 194, but about half the size. Used for the turn signal, shift light, and warning lights between the speedometer and tachometer
1445 -- Not really sure what this is used for. Looks like a miniature version of the stop/turn light
-Matt
White '94 YJ Sport
UltimatE is offline
post #3 of 20 Old 09-02-2008, 06:15 PM
FarrellX
you found brighter bulbs for your dash? meaning, turn signals, high beam light, etc? i cant see mine at all during the day either, even at night they arent the brightest...
Mine 1999 XJ
SOLD Hers 1999 XJ 2", 31" MTs
R.I.P. 88 YJ 6 1/2", 36" Iroks, '99 4.0, etc. etc.
FarrellX is offline
post #4 of 20 Old 09-02-2008, 06:52 PM
barrios35
Good place to start. I ordered some LED's for my Infiniti and they are awesome. Look good too
http://autolumination.com/194.htm
barrios35 is offline
post #5 of 20 Old 09-02-2008, 08:05 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
No, I haven't upgraded yet... I found the autolumination site and superbrightleds.com
Going to order some LED's soon though, since its impossible to see the warning lights during the day.
-Matt
White '94 YJ Sport
UltimatE is offline
post #6 of 20 Old 09-24-2008, 08:57 PM
Tobey
Any updates on this? I'd like to try the LEDs in the gauges / dash.
Also what size bulbs are used in the HVAC unit?
Tobey is offline
post #7 of 20 Old 09-25-2008, 04:59 PM
RikRotorhead
There are several different styles of 194 bulbs on that site.
It look's like the "matrix" design would work best to throw out a wide pattern.
I am installing the white face overlays in my guages for better daytime visibility, and I would like them to be red at night.
It will be interesting to see what you end up with as a result. Keep us posted.
Actually, I need a spotlight on my gas guage. All my other cars have an audible and visual reminder when the fuel is low. I've run out twice in the Heep. Now my kids watch it for me! LOL.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #8 of 20 Old 09-25-2008, 05:36 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You might want to reconsider the red idea. It may be fine on a F111, but in a Jeep, not for me. I swapped ini Autometer gauges and hate the red I made the lights. Next time I have to pull the panel, I'm going back to white.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #9 of 20 Old 09-25-2008, 06:49 PM
Tobey
I think the white faced gauges would make the lighting color more obvious and brighter. I can understand why you wouldn't like the red lighting on a white background, it must be VERY red.
I tried red bulbs on my 1990 YJ and I loved them, and will probably do the red on this YJ too, but I had the stock black faced gauges.
Tobey is offline
post #10 of 20 Old 09-25-2008, 10:33 PM
RikRotorhead
Do you have a pic of them on at night?
I'm used to red instruments at night in the rotorcraft I fly.
I wish I flew F111's.
It probably is a moot point to have red when the lighting all around you is white, unlike 2000 feet up in the sky at night with only gournd lighst that are white.
But my Jeep is red, and I was thinking it might look better too.
Tial and error, and input from others.
So if you have any night pics I'd appreciate it.
RJC#512
post #11 of 20 Old 09-25-2008, 10:35 PM
xjpro
Another good source for LED's
http://www.oznium.com/
xjpro
01 xj limited
ZJ rear disc brakes with working parking brake
Electric fan conversion with spal fan controller
xjpro is offline
post #12 of 20 Old 09-25-2008, 11:37 PM
JeepMan1975
You might want to reconsider the red idea...I swapped ini Autometer gauges and hate the red I made the lights.
For anyone wanting to see the red at night, the same company makes a set of gauges known as the ES gauges. These guages are somewhat close in appearance to bone stock (less the digitial odometer), and at night, they illuminate red.
Red on black would probably be better than red on white. Just my $0.02. Anyway, there's a visual on the link so that you can see these gauges illuminate: http://www.autometer.com/cat_gaugeop.aspx?sid=67
JeepMan1975 is offline
post #13 of 20 Old 01-09-2010, 01:42 AM
pawarren
Does anyone have a schedule of how many bulbs are required behind the dash?
I see these part numbers listed under "Instrument general" at the autolumination site:
37
53
658
74
PC194
Also, do LED bulbs dim with the dimmer control or are they constant brightness?
DD=2005 WK 5.7 Hemi QDII Stock
Fn=1998 XJ 4.0 (work in progress: lift, 2WD->4x4)
pawarren is offline
post #14 of 20 Old 01-09-2010, 01:46 AM
remery829
this is an epic revival....
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #15 of 20 Old 01-09-2010, 06:38 AM
YJBlues
YJBlues's Avatar
Yes, but it's an excellent use of the search function!
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights Cajun90YJ YJ Wrangler Technical Forum 9 10-03-2010 05:33 PM
Headlights and dash lights don't turn on, but the amber lights do mniemela YJ Wrangler Technical Forum 1 06-10-2010 04:11 PM
Running lights and Dash lights wont work!? Help nield13 YJ Wrangler Technical Forum 4 12-12-2009 02:22 PM
No dash lights, tail lights or parking lamps BlkBird TJ Wrangler Technical Forum 5 01-11-2008 08:03 PM
