LED lights ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > LED lights ?
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 03-17-2014, 05:17 PM   #1
crackedcornish
LED lights ?
anybody making LED tail lights and/or marker lights that are simple plug ins yet, or at least include the needed connectors, so I don't have to cut up my stock stuff?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 05:46 PM   #2
92 Green YJ
You can just swap in led bulbs in the stock housings. Would cheaper than a whole assembly. Hit up superbrightleds.com and order the size bulbs you need. Simple swap. Also remember to upgrade your flasher relay or install resistors or your gonna have super fast blinkers.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 06:03 PM   #3
crackedcornish
I was thinking about going that route, but wanted to see if there was anything with a bit lower profile than the stock box lights out there first.
I was looking at the lights from Savvy, and I like everything about them except the part about having to splice them in, instead of being able to just plug and play
http://shop.savvyoffroad.com/product...5&categoryId=3
Unread 03-17-2014, 06:06 PM   #4
92 Green YJ
It's really not that difficult to splice wires. And for the tail lights your looking at 4 per side. Should be a super quick and easy job.
Unread 03-17-2014, 06:14 PM   #5
crackedcornish
but where would I get the connectors from..like I said, I don't want to cut up my stock stuff. That makes it difficult to reuse or sell them later.
Unread 03-17-2014, 06:20 PM   #6
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Available at any parts house or hardware store. You can even soldier and heat shrink for an additional 20 min of patience.
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 06:21 PM   #7
92 Green YJ
Well the stock lights won't fetch you much. They are basically just trailer lights you can buy for 5 to 10 bucks at any auto parts store. You could try and track down a YJ at a junk yard and cut the connectors off of it and use those if your really that worried about cutting up the factory wires.
Unread 03-17-2014, 06:23 PM   #8
92 Green YJ
Would not use these on any jeep that's going to see any kind of wheeling. And definitely not the cheap ones. If you insist on using those crappy things at least get the more expensive heat shrink style. Personally I go all out and solder and heat shrink every connection. It's the best method by far.
Edit:
These are what I did for my led tail lights. I wanted something different.
Unread 03-17-2014, 06:36 PM   #9
Mobile_Homie
Desert Rat
Edit:
I just did a quick google for "butt splice", I also soldier and heat shrink my junk.
Mark
Click here
Unread 03-17-2014, 07:37 PM   #10
crackedcornish
allrightythen I guess I'll hit up my jeep club members first to see if anybody has any broken housing lying around I can cannibalize for the wiring and connectors. If no luck there, I'll visit the local salvage yards.
looks like I'll have some time, since the savvy lights are on back order at the moment
Unread 03-17-2014, 08:24 PM   #11
mamzerook
look on the websites for grote,peterson mfg and trucklight. these led lights are available at any heavy truck shop. ie. kenworth peterbilt etc. they normally have a huge selection in stock and can get anything in the supplier catalog.
mamzerook is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 08:43 PM   #12
jsawduste
2006 YJ Wrangler
I run the Savvy taillights and wired them up with Weatherpack connectors. Weatherpack`s are what is on your Jeep now and IIRC the Savvy lights come with WP`s as part of the kit.
jsawduste is offline   Reply With Quote Quick reply to this message
Unread 03-18-2014, 08:56 PM   #13
Richard_
Wow , there really proud of them lights
Richard_ is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 08:52 AM   #14
crackedcornish
if you know where to get some LED's tail lights in a billet aluminum low profile housing that don't require any cutting of the tub to install any cheaper than these...please, tell me where I can get them
Unread 03-19-2014, 01:09 PM   #15
Xpress
Flush mount lights will always require you to cut into your tub. Honestly, not that big a deal...
Your OEM tail lights are basically worth about as much as they weigh in dirt, seldom few want them, especially when you can get tail lights that would cost you less than $40 for both... Cutting off the connectors to re-use them is the best method if you want plug and play. That's what I did with the lights I bought from Super Bright LED's, made it incredibly simple for the new owner to just plug and play onto his YJ.
[URL="http://www.jeepforum.com/forum/f12/another-5-2l-yj-thread-1503048/"]My 5.2L Build thread[/URL]
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
[QUOTE=mudsweatNgearz;21162729]Leave em off and weld an I beam on. Bumperetts just scream homo.[/QUOTE]
"A well regulated Militia, being necessary to the security of a free State, the [B][I]RIGHT[/I][/B] of the people to keep and bear Arms, [B][I]SHALL NOT BE INFRINGED[/I][/B]."
Xpress is offline   Reply With Quote Quick reply to this message
