LED issues!!! HELP!! - Page 2 - JeepForum.com
post #16 of 22 Old 04-24-2013, 06:48 PM
sjones26573
Originally Posted by Xpress View Post
What brand of lights were they? There are still a lot of LED lamps that do have resistors built into them, then there are the cheap ones (like from HF) that people around here cheap out on then get all sorts of issues because of the current draw.
Depends on which lamps you buy. Don't cheap out, and do your research first.
You're telling this to a guy who already has LED everything on the rear. And yes, I did buy the cheapo Blazer brand walmart LEDs. And yes, they worked fine. All of these 4" LED tails are designed to be installed in semi's and work trucks. They are plug and play.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #17 of 22 Old 04-24-2013, 07:16 PM
Jeep43
Get the truck lite 4050d I installed these with no extra flashers or resistors. They were only like $15 at napa.
Jeep43 is offline
post #18 of 22 Old 04-24-2013, 07:18 PM
sjones26573
There are plenty of cheap lights he can buy instead, but for right now he's trying to fix what he's got. Chances are, the lights aren't the problem.
Jeep-Owner.com
post #19 of 22 Old 04-24-2013, 08:00 PM
Fenix85182
Fenix85182's Avatar
I can't remember. They were standard 4" with a decent amount of LEDs. I think I went with something that was DOT approved, just for visibility's sake. The reverse lights I put in were 2.5" LEDs I scored off of eBay. I was ready to have to install resistors if the blink speed was crazy, just happened to not be the case.
If I'm not mistaken, resistors are usually installed when the blinker current draw isn't as high as the relay expects, thus it blinks quickly, thinking there is a problem. The front blinkers are still regular bulbs, which have the correct power draw, so the relay is satiated.
Anyway, OP, you said resistors are all four corners? Did you install LEDs in the front, as well? If they worked fine before LED swap, there must be a bad ground somewhere. When all four are blinking, does the dash show both indicators flashing, or just the side you chose? I'm thinking you can probably narrow down the problem by disconnecting each side independently and testing it to see if it fixes it. Once you disconnect the corner that is a problem and everything functions as normal, as least you know where to check the wiring.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #20 of 22 Old 04-25-2013, 11:10 AM Thread Starter
Jeepmonster33
Yeah we put equalizers at all 4 corner, we have led rears for brake, running, and turn, in the front we have led blinkers and runnin lights, i will check grounds but i do remember for the fronts my buddy put the blinkers and running lights to the same led??
Jeepmonster33 is offline
post #21 of 22 Old 04-25-2013, 11:39 AM
sjones26573
You can do that but you have to used diodes on each lead and a resistor on the driving light lead. Might be the problem.
Jeep-Owner.com
post #22 of 22 Old 04-27-2013, 10:21 AM
msprooch
Remember guys resistors "resist" the flow of current. They dissipate the excess energy off as heat.
msprooch is offline
blinkers , led , lights , tail lights , YJ
