LED issues!!! HELP!! - JeepForum.com
post #1 of 22 Old 04-24-2013, 08:59 AM Thread Starter
Jeepmonster33
Been working on a 91 YJ and installed LED tail lights and blinkers, i have a LED flasher in it and have resistors at all 4 corners. When i turn on the blinkers all 4 lights blink, when the brakes applied they work normally. im stumped and haven't been able to find any info on it.
Jeepmonster33 is offline
post #2 of 22 Old 04-24-2013, 09:50 AM
SeanB95YJ
if you have an electronic flasher (EL-12 I think?) then there's no need for the additional resistors you mentioned. I'm not saying that's necessarily the cause of your problem, but no sense having it there.... it might clear it up, but if not, at least that's one thing you can knock off the list to check.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 22 Old 04-24-2013, 10:05 AM Thread Starter
Jeepmonster33
Ive checked a lot off the list haha, we started with the electric/LED flasher-nothing, then the load equalizer-nothing. So now im stumped. It all worked fine before the LED by the way.
post #4 of 22 Old 04-24-2013, 10:59 AM
SeanB95YJ
did you check the polarity on the lights? LEDs can't be wired backwards the way a regular filament bulb can
swap/build thread:
post #5 of 22 Old 04-24-2013, 11:25 AM Thread Starter
Jeepmonster33
Im 99% sure polarity is right, brake lights and running light work fine.
post #6 of 22 Old 04-24-2013, 11:30 AM
sjones26573
If it all lights up, then polarity is correct. Something else is wrong. These Jeeps are extremely finickey about LEDs
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #7 of 22 Old 04-24-2013, 12:08 PM
msprooch
Draw up a wiring diagram and post it on here. There are a few electrical types around...some who work with automotive LEDs for a living
msprooch is offline
post #8 of 22 Old 04-24-2013, 12:58 PM
Xpress
Are you using a no load electronic flasher?
Sent from a Jeep.
All about that unibody life.
Xpress is offline
post #9 of 22 Old 04-24-2013, 12:59 PM
jokerchief462
If more than one light is coming on at a time chase the grounds first you may be getting some feedback. I know mine were bad and had to be cleaned up bare metal works best.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #10 of 22 Old 04-24-2013, 02:10 PM Thread Starter
Jeepmonster33
this is the flasher we're using---Littelfuse Blister Pack - Electronic Flasher
What if i were to add diodes into the positive side of the circuit?
post #11 of 22 Old 04-24-2013, 02:26 PM
msprooch
Diodes allow current to flow in only one direction. If you orientate them in the proper way you can put them on the negative side and get the same result.
msprooch is offline
post #12 of 22 Old 04-24-2013, 03:33 PM
Fenix85182
Fenix85182's Avatar
When I installed my LED brake lights and LED reverse lights, I just spliced them in to the harness--no diodes/resistors/or flasher relay change. I don't believe the lights had anything special built in, and they just worked correctly, regular speed. I did have a few ground issues, but that resulted in them not lighting at all, rather than too many lights lighting.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #13 of 22 Old 04-24-2013, 03:35 PM
sjones26573
Which is how it's supposed to be...
Jeep-Owner.com
post #14 of 22 Old 04-24-2013, 05:20 PM
Xpress
What brand of lights were they? There are still a lot of LED lamps that do have resistors built into them, then there are the cheap ones (like from HF) that people around here cheap out on then get all sorts of issues because of the current draw.
Depends on which lamps you buy. Don't cheap out, and do your research first.
Xpress is offline
post #15 of 22 Old 04-24-2013, 05:36 PM Thread Starter
Jeepmonster33
thats what we did, just spliced them in..then came the flasher, then the equalizers, the only thing is we dont have reverse lights at all.
blinkers , led , lights , tail lights , YJ
