-   -   LED issues!!! HELP!! (http://www.jeepforum.com/forum/f12/led-issues-help-1513863/)
Jeepmonster33 04-24-2013 09:59 AM
Been working on a 91 YJ and installed LED tail lights and blinkers, i have a LED flasher in it and have resistors at all 4 corners. When i turn on the blinkers all 4 lights blink, when the brakes applied they work normally. im stumped and haven't been able to find any info on it.:mad:
SeanB95YJ 04-24-2013 10:50 AM
if you have an electronic flasher (EL-12 I think?) then there's no need for the additional resistors you mentioned. I'm not saying that's necessarily the cause of your problem, but no sense having it there.... it might clear it up, but if not, at least that's one thing you can knock off the list to check.
Jeepmonster33 04-24-2013 11:05 AM
Ive checked a lot off the list haha, we started with the electric/LED flasher-nothing, then the load equalizer-nothing. So now im stumped. It all worked fine before the LED by the way.
SeanB95YJ 04-24-2013 11:59 AM
did you check the polarity on the lights? LEDs can't be wired backwards the way a regular filament bulb can
Jeepmonster33 04-24-2013 12:25 PM
Im 99% sure polarity is right, brake lights and running light work fine.
sjones26573 04-24-2013 12:30 PM
If it all lights up, then polarity is correct. Something else is wrong. These Jeeps are extremely finickey about LEDs
msprooch 04-24-2013 01:08 PM
Draw up a wiring diagram and post it on here. There are a few electrical types around...some who work with automotive LEDs for a living;)
Xpress 04-24-2013 01:58 PM
Are you using a no load electronic flasher?
Sent from a Jeep.
jokerchief462 04-24-2013 01:59 PM
If more than one light is coming on at a time chase the grounds first you may be getting some feedback. I know mine were bad and had to be cleaned up bare metal works best.
Jeepmonster33 04-24-2013 03:10 PM
this is the flasher we're using---Littelfuse Blister Pack - Electronic Flasher
What if i were to add diodes into the positive side of the circuit?
msprooch 04-24-2013 03:26 PM
Diodes allow current to flow in only one direction. If you orientate them in the proper way you can put them on the negative side and get the same result.
Fenix85182 04-24-2013 04:33 PM
When I installed my LED brake lights and LED reverse lights, I just spliced them in to the harness--no diodes/resistors/or flasher relay change. I don't believe the lights had anything special built in, and they just worked correctly, regular speed. I did have a few ground issues, but that resulted in them not lighting at all, rather than too many lights lighting.
sjones26573 04-24-2013 04:35 PM
Which is how it's supposed to be...
Xpress 04-24-2013 06:20 PM
What brand of lights were they? There are still a lot of LED lamps that do have resistors built into them, then there are the cheap ones (like from HF) that people around here cheap out on then get all sorts of issues because of the current draw.
Depends on which lamps you buy. Don't cheap out, and do your research first.
Jeepmonster33 04-24-2013 06:36 PM
thats what we did, just spliced them in..then came the flasher, then the equalizers, the only thing is we dont have reverse lights at all.
The time now is 09:08 PM.
