LED dashlights... - JeepForum.com
post #1 of 19 Old 04-01-2013, 08:35 AM Thread Starter
mikes95YJ
LED dashlights...
well im looking to put red LED lights for my dash. wondering if its as simple as buying a few bulbs and taking out the old one replacing them with the new ones... im completely clueless so any help would be appreciated. this is being done on a 95 yj. thanks for any help
mikes95YJ is offline
post #2 of 19 Old 04-01-2013, 08:59 AM
Wranglin4Life
It is very easy. There are lots of of threads about it. It's a 194 wedge based bulb for most of the gauges. You can find them at superbrightleds.com
Plug and play tho. Very easy!
Wranglin4Life is offline
post #3 of 19 Old 04-01-2013, 09:06 AM Thread Starter
mikes95YJ
It sounded easy and since this is a project from the ground up everything is apart right now. Thanks for the response!
post #4 of 19 Old 04-01-2013, 01:54 PM
Flajeeper1
1987 YJ Wrangler
Might look at this for your gauges at jeepwhiteguages.com. They have various colors for the gauge faces. If you do it make sure you get the needle paint if yours are faded.
http://www.jeepwhitegauges.com/dashboard4.jpg
Flajeeper1 is offline
post #5 of 19 Old 04-01-2013, 01:55 PM
Flajeeper1
1987 YJ Wrangler
post #6 of 19 Old 04-01-2013, 01:59 PM
Flajeeper1
1987 YJ Wrangler
Oppss. The website does not recommend using LED bulbs. Sorry, bad suggestion.
post #7 of 19 Old 04-01-2013, 06:19 PM Thread Starter
mikes95YJ
So when I replace the bulbs I have to replace the plastic plates and paint the needle? I'm not sure what to call it haha!
post #8 of 19 Old 04-02-2013, 01:24 PM
Flajeeper1
1987 YJ Wrangler
No, you don't have to do anything else when you change to the LED lights. I had installed some of the white face gauge covers on another YJ and thought they looked nice. I read the info on the website and it states that if you use LED lights don't use the white face gauge covers. So, my bad for suggesting them.
post #9 of 19 Old 04-02-2013, 01:31 PM
Berniebikes
I'm using red LEDs to match the head unit Red color. Things show up just fine with the stock gauges. I've though about doing the blue one side, red other side LED for the speedometer and tachometer so you get this blue fade to purple fade to red look on the gauge face, just haven't gotten around to it yet, but yeah, the red ones are just fine.
B
Berniebikes is offline
post #10 of 19 Old 04-03-2013, 12:23 PM
timatoe
timatoe's Avatar
I also use red ones and can see everything just fine. Although I have Autometer Phantom II's for all the gauges except the speedo and tach. I'm cheap so I ordered a bunch of LED's on eBay that came from China, I think I got all I needed plus extras for less than $15 including shipping.
timatoe is offline
post #11 of 19 Old 04-09-2013, 10:48 AM Thread Starter
mikes95YJ
For the superb bright LED sight what beam angle should I get?
post #12 of 19 Old 04-09-2013, 10:53 AM
Jims-87YJ
1987 YJ Wrangler
I went with these overlays and am planning on getting LED's soon (Blue) http://www.whitegauges.net/
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #13 of 19 Old 04-09-2013, 11:20 AM
Berniebikes
I used mostly WLEDX5 wide angle bulbs with a 220 degree angle
post #14 of 19 Old 04-09-2013, 11:39 AM Thread Starter
mikes95YJ
What about 120 degree? That's the highest options besides 90 on the bright light LEDs website
post #15 of 19 Old 04-09-2013, 11:41 AM
Berniebikes
I'm sure it will work, but seemed to me the number I noted in a 194 wedge base bulb with 220 degree spread is better. I just looked at the super bright led site and it's there.
