Leans AX-15 External Slave Swap With Pics! - Page 6 - JeepForum.com
post #76 of 179 Old 03-21-2013, 08:49 PM
jeepcrazy93
With the help of this thread, i did the conversion. The hardest part was using those stupid metal clips. Other than that its pretty simple.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #77 of 179 Old 09-29-2013, 08:03 PM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
Sub'd for future reference. Thanks for a extremely detailed write up!
YJOTM January 2017
Hoxie is offline
post #78 of 179 Old 12-10-2013, 08:54 AM
King_Inky
Quick question,
I have a 98TJ 4.0L with an AX15 that currently has the external slave setup. My trans took a crap on me last night, so I will be swapping this weekend. The "new" trans is from a U-Pull-It junkyard from a 93 Grand Cherokee IIRC. Regardless, it is the AX15, but that one is an internal slave setup. Do I need to buy anything to do the swap, or can I use all the parts from my current trans to do this? I guess its more about the bearings, as I assume I can reuse the bellhousing, shift fork, and cylinder (replaced this summer, so I know it is good). I need to pick up these parts soon, and any help is greatly appreciated!
King_Inky is offline
post #79 of 179 Old 12-10-2013, 12:30 PM
Opihi59
from here it gets rough
Opihi59's Avatar
This actually merits its own thread, post up your own new thread on this, and send me a PM so I don't miss it, and I will answer all your questions on this topic.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #80 of 179 Old 12-10-2013, 12:54 PM
King_Inky
Done, PM sent, and if anyone else would like to discuss, the new thread can be found at:
http://www.jeepforum.com/forum/f19/a.../#post18415834
Thanks!
post #81 of 179 Old 02-16-2014, 09:03 AM
glenbjackson19
JUST by looking at your first post helped me ALOT BRO!!! thank you very much.
glenbjackson19 is offline
post #82 of 179 Old 02-16-2014, 09:11 AM
Louie4
Great write-up. I'm on the final leg of this swap. Oh and for anyone who may need one, I have an extra clip for the fork that goes over it and the ball.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #83 of 179 Old 04-30-2014, 08:49 PM
yellowoctupus
http://www.autozone.com/autozone/acc...er=542225_0_0_
Don't know if these are another alternative if you want to make a braided line, but I ran across them accidentally on the Autozone website....
yellowoctupus is offline
post #84 of 179 Old 05-05-2014, 08:55 AM
BassProCamaro97
Hey guys after some unfortunate events I'm in the process of doing this swap as well. I just ordered these parts and want another set of eyes to see if I missed anything that is needed.
Fork, Release Spring, Bearing retainer and seal, Throw out bearing, External slave, Bell Housing and pivot ball.
Based on what I read in this thread I think I should have it all. Am I missing anything?
Thanks guys.
~Jim~
BassProCamaro97 is offline
post #85 of 179 Old 05-05-2014, 11:17 AM
Opihi59
Opihi59's Avatar
Clutch fork....
Opihi59 is offline
post #86 of 179 Old 07-07-2014, 03:16 PM
mhollifi
Will either bellhousing or long nose bearing retainer from ax5 work on this conversion if going on a 91 yj with 4.0l and ax15 trans?
mhollifi is offline
post #87 of 179 Old 07-07-2014, 04:42 PM
Louie4
You are probably already on the path to doing the swap but don't forget the retaining clip for the for for and pivot ball. I actually have an extra.
Lou
YJOTM July 2012
YJOTM February 2014
post #88 of 179 Old 07-07-2014, 05:08 PM
Opihi59
Opihi59's Avatar
The AX 5 and AX 15 long snout front bearing retainer and respective bellhousings are not interchangeable.
The bellhousing for the NV3550 is interchangeable with the AX 15, but the front bearing retainers are not.
Opihi59 is offline
post #89 of 179 Old 07-07-2014, 05:20 PM
Opihi59
Opihi59's Avatar
Clutch Release Spring: 4338855
Opihi59 is offline
post #90 of 179 Old 07-07-2014, 09:42 PM
mhollifi
Thanks for the info. When I get all my parts lined up, I am sure that I will be back here asking questions. Once again, thanks all for the info.
mhollifi is offline
External to internal Slave swap, can it be done??? rustywrangler YJ Wrangler Technical Forum 1 12-02-2009 06:32 AM
Help: external clutch slave cylinder swap Blacksmith13 YJ Wrangler Technical Forum 0 02-26-2009 09:47 AM
Swap to external slave Fenix85182 YJ Wrangler Technical Forum 3 09-19-2006 09:50 AM
Completed External Slave Swap rbn1357 YJ Wrangler Technical Forum 0 08-28-2006 03:05 PM
Internal/External Slave swap TellyDSP YJ Wrangler Technical Forum 13 05-04-2005 09:26 PM
