Leans AX-15 External Slave Swap With Pics! - Page 5 - JeepForum.com
post #61 of 189 Old 06-26-2012, 08:45 AM
jokerchief462
I'm all good the Master Cylinder I received was for a 97 not a 94. When I went to AZ they swapped it out no questions. So now I am on my way. Results and pics to follow. Thanks.
jokerchief462 is offline
post #62 of 189 Old 12-04-2012, 02:32 AM
RogueAkita
1991 XJ Cherokee
First of all thank you for passing along your knowledge, we really appriciate you. That said, I just did this conversion on my 91XJ, using a 94 NV3550 bellhousing, AdvanceAdapters slave kit #716340, NovakConversions pilot bushing #PB-7501295, front bearing retainer #4636382, release arm #5210755M, adjustable throwout bearing #TB2 and Napa Auto Parts new clutch master. Upon start up two negative effects occured, I blew out my new clutch slave and started leaking transmission fluid, both out the dust cover. I did torque to spects. I have yet to pull it all out again to see where it went wrong. My thoughts are I didnt properly seal the bearing retainer (silicone but no gasket) or any seals not mentioned I followed the thread and crossed referenced with both Hayes & Chilton manuals for all other rational Q's. All clutch hydraulics are new and all fluids new. Any thoughts before I reengage this stuff? Respectfully, RogueAkita.
RogueAkita is offline
post #63 of 189 Old 12-04-2012, 09:06 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Are you sure you were leaking tranny fluid? The sealing process you used under the front bearing retainer was correct, just need RTV, but did you put a seal in the retainer? IF you blew out your clutch slave, you'd be leaking brake fluid (also). The way this happens is if you do not have the clutch slave piston nestled properly in the dimple in the release arm; it will just launch when you press the clutch pedal.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #64 of 189 Old 12-10-2012, 07:20 PM
mncdriver
1987 YJ Wrangler
Great Info!
mncdriver is offline
post #65 of 189 Old 12-13-2012, 09:22 AM
2cjs
2cjs's Avatar
im in the process of doing this on my wifes 89' yj.
its been brought to my attention that on the 89 ' ,u have the 4.2.
and the flywheel is thicker for the 4.0.
the difference is 1/4 inch.
so i am going to put the 4.0 flywheel in so i wont get clutch slippage.
4.2 flywheel is 1 inch thick approx
4.0 flywheel is 1 1/4 inch. thick approx.
hope that helps fellow jeepers.
kenny
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #66 of 189 Old 01-14-2013, 08:25 AM
ctm
kenny
Can someone please explain the difference in flywheel thickness and doing the external slave swap on a 4.2 vs. 4.0. Does it mean the new throwout bearing will not reach far enough? I have a 90 YJ with 4.2 and AX15 internal slave. I was planning on using the existing flywheel and clutch which currently only have about 20K miles on them. I have located a TJ NV3550 bellhousing and throwout lever/bearing that I can get. Can I not use my flywheel and/or clutch for the conversion?
ctm is offline
post #67 of 189 Old 01-15-2013, 02:08 PM Thread Starter
Leans93
She's my density...
Leans93's Avatar
That post doesnt make any sense to me. Perhaps someone else will chime in and correct me if I'm wrong but a 4.0L needs the flywheel for a 4.0L and the same with the 4.2L. The flywheel is not interchangeable and is directly related to the engine and not the transmission. The CPS reads the teeth on the flywheel so it is specific to the engine. I wouldn't change mine if I were you.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #68 of 189 Old 01-17-2013, 07:30 AM
RogueAkita
1991 XJ Cherokee
Well Opihi59, I found the bearing retainer seal to inputshaft was over looked. I ended up swapping the one from the internal retainer and replacing the fluid. The slave issue was as you said, on install one retaining tab was broke and over shot the throwout arm completely. Thanks to everyone here on JeepForum for building my confidence to undertake this project with success. I got chocolate mousse as a gift for christmas wrapped in my engine block, so my next project is a 4.6 stroker.
post #69 of 189 Old 01-20-2013, 07:11 PM
mncdriver
1987 YJ Wrangler
just finished the external swap on my yj, it had the internal ax15 swap previously. Jeep is 4.2l. New Clutch kit, throw out bearing, slave cylinder and AA adapters and line kit. Seems clutch is at the bottom of the throw. i think it should be higher. any ideas?
post #70 of 189 Old 01-21-2013, 06:06 AM
ctm
I wonder still if it is related to flywheel thickness. Could you bring the clutch throw higher by making some sort of adjustment on the clutch master rod to the pedal.
ctm is offline
post #71 of 189 Old 01-21-2013, 03:33 PM
mncdriver
1987 YJ Wrangler
Ok, so if the throw was a 1/4 inch longer does anybody think that would help? Just thoughts off the statement made by 2cjs. Ideas?
post #72 of 189 Old 01-21-2013, 03:43 PM
JeepinJeremy
re-blead the system and follow AA directions with there kit. aslong as you used a 4.2 flywheel and a match clutch set for a yj/xy/tj with an ax15 external slave it should work without issue. Have done this swap many times on cj7 with 258 and early yj's.
JeepinJeremy is offline
post #73 of 189 Old 01-21-2013, 03:46 PM
JeepinJeremy
even if you used a 4.0 flywheel out of a yj it still works without issue. only difference is the cutouts on the ouside of the flywheel for the crank sensor. teeth are the same at 168.
post #74 of 189 Old 01-21-2013, 03:49 PM
mncdriver
1987 YJ Wrangler
Thanks Jeremy, I used the stock OEM replacement clutch kit for my year YJ. Again it is not "Bad" but just seems like it should be higher.
post #75 of 189 Old 01-21-2013, 03:55 PM
JeepinJeremy
probebly just needs to be re-bled clutchs are the same minus the throwout bearing and pilot bushing.
While people are still here and reading this.
WANTED AX15 External slave bellhousing for my XJ conversion. PM me if you want to sell me one.
External to internal Slave swap, can it be done??? rustywrangler YJ Wrangler Technical Forum 1 12-02-2009 05:32 AM
Help: external clutch slave cylinder swap Blacksmith13 YJ Wrangler Technical Forum 0 02-26-2009 08:47 AM
Swap to external slave Fenix85182 YJ Wrangler Technical Forum 3 09-19-2006 08:50 AM
Completed External Slave Swap rbn1357 YJ Wrangler Technical Forum 0 08-28-2006 02:05 PM
Internal/External Slave swap TellyDSP YJ Wrangler Technical Forum 13 05-04-2005 08:26 PM
