Quantcast leaning tower of jeep? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > leaning tower of jeep?
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 05-11-2005, 10:07 AM   #1
rockhead
Does any one else's jeep lean. My front passenger side is much lower. I took some measurements and everything is pretty much even until you get up to the body. I have an 1 1/2" more clearence over my driver tire than my passenger tire. Any ideas on what it is? Could my axel be shifted or something? It does look like the perch on passenger side of the axel has some damage.
Thanks for any help
90 YJ 4.2
33" and open
trail project
rockhead is offline   Reply With Quote
Old 05-11-2005, 10:16 AM   #2
sjlplat
If everything is even from the suspension to the frame, that might indicate some bending in the fender or tub, maybe body mounts.
sjlplat is offline   Reply With Quote
Old 05-11-2005, 10:22 AM   #3
LandRover
Blown shock?
I know you said you took "some measurements", but it's a possibility...
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Maxxis Bighorn 32's
LandRover is offline   Reply With Quote
Old 05-11-2005, 10:41 AM   #4
rockhead
Measured the shock also they were pretty close. If it is a body mount would a body lift fix it. I am considering doing a 1" bl lift.
90 YJ 4.2
33" and open
trail project
Old 05-11-2005, 10:44 AM   #5
sjlplat
Depends. If it's a cracked mount at the frame, or a collapsed mount at the body, a lift wouldn't do anything for ya. If it's simply the rubber, that can be replaced with a kit that includes everything.
Old 05-11-2005, 01:58 PM   #6
Wif
I would think it would still lean .. unless you only put the lift on the side that's low ..
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote
Old 05-11-2005, 03:55 PM   #7
milosz4
I have the same problem
1990 I-6 with the passenger side lean - My drivers side is about 1"higher and after checking the spring heights and angle of the body - it seems like the body is twisted or not fully supported on the passenger side - Visually the body mounts I can see look fine - about even on both sides - but I am assuming the problem lies therein
1990 YJ
Sahara - needs TLC
milosz4 is offline   Reply With Quote
Glock Forum
