Leaking..where from? - JeepForum.com
post #1 of 6 Old 10-21-2001, 12:49 PM Thread Starter
JeepinGirlinFl
JeepinGirlinFl's Avatar
Ok, I have researched the forum and I have a feeling that the windshield retainer is clogged and is causing water to leak inside the jeep. But, I am not sure. I looked around under the jeep to find some type of tube to check to see if it is clogged and I didnt see anything. Can anyone direct me or even include a picture? I keep getting wet <grin> in my jeep - but it is a lil too much.
Thanks for the help!!
87 Wrangler
4.2L I6
2.5 Skyjacker Lift, chrome grill, steel step bumperettes, new bestop trailmax front seats, K&N, Por15'd frame, Por15'd cab with por15 topcoat....whatever is nasty is being removed and restored!
JeepinGirlinFl is offline
post #2 of 6 Old 10-21-2001, 01:29 PM
glm 87 wrangler
Found out my tube was gone and found the little hole it comes out at,it was clogged,still leaks in other areas, still searching..for the other leaks.Let you know what I find..One is around the heater box under the dash.Have some one spray water while you look and see were it comes from..
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 6 Old 10-21-2001, 03:01 PM Thread Starter
JeepinGirlinFl
Where should the water leak out to? I am not even sure if I have the hose or not.
87 Wrangler
4.2L I6
post #4 of 6 Old 10-21-2001, 03:25 PM
glm 87 wrangler
Well the easy way is to take a cup of water and pour it in the center vent and have someone under the jeep while you do it.FUN for who ever is under there.Look by the fire wall a little to the passanger side it should be around that area the tube could have also been tucked under somthing when worked on before between the fire wall and inside compartment,better jet i will craw under mine so I can better tell you were to look it been a week or so when i checked mine from a posting before when i found I did not have one..Just found the hole...
post #5 of 6 Old 10-21-2001, 03:43 PM
glm 87 wrangler
OK JUST got a little wet it will leak right on to the stater there is like a metal
tube wide oval shape,Hope this helps,let me go dry off.. Again it will be right by and above the stater on the pasenger side.take a screw driver and clean it out dont hit the stater wires might get ran over LOL just kidding.hopr this helps
post #6 of 6 Old 10-21-2001, 05:48 PM
glm 87 wrangler
I did forget to say if you have AC on your
jeep under your battery tray you will see a hose by the heater fan motor on the fire wall,
that goes to the AC.Did not want to confuse you more than I already have
Leaking AX-5 EJames1226 YJ Wrangler Technical Forum 8 02-20-2008 03:48 PM
oil now leaking--need help! jsr86 TJ Wrangler Technical Forum 1 02-15-2008 12:38 PM
AX-15 leaking Vetteman TJ Wrangler Technical Forum 0 03-03-2007 01:21 PM
SYE Leaking? Viet15philong TJ Wrangler Technical Forum 15 08-10-2005 08:18 PM
leaking oil but from where detroitwhat? YJ Wrangler Technical Forum 4 04-30-2004 08:47 PM
