leaking transfer case from speedo cable - JeepForum.com
post #1 of 3 Old 04-05-2010, 01:46 PM Thread Starter
arnelio2
I have a 91 leaking atf from where the speedo cable goes into the transfer case. Does anyone know the name of the hardware needed to replace this. It isn't the cable itself, but where it bolts into the tc. The previous owner had a coat hanger wrapped around, but it has finally failed. Also, is this difficult to replace, or just bolt back in place? Thanks
arnelio2 is offline
post #2 of 3 Old 04-05-2010, 01:51 PM
jbolty
jbolty's Avatar
just bolts right in, unless the hole is stripped or the bolt broken. look at that first.
the bracket is simple but probably a dealer or junkyard only part.
if the tail cone is damaged there are usually a lot of spares around from guys doing SYE installs and taking them off.
jbolty is offline
post #3 of 3 Old 04-05-2010, 04:00 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Dodge part number 4883434AA, it's called a seal package for the speedometer gear housing.
5.7YJ is offline
Transfer case shift cable broke SargeW JK Wrangler Technical Forum 16 07-17-2012 09:13 PM
Novak transfer case cable linkage - opinons? kakarak TJ Wrangler Technical Forum 21 04-01-2010 09:39 PM
4wd/ transfer case cable stuck? ...broken? dirtyjpwrangler JK Wrangler Technical Forum 7 02-17-2010 07:57 PM
Speedo Cable on Cherokee t-case 88_cherokee YJ Wrangler Technical Forum 0 02-14-2009 09:44 PM
ATF 4 Leaking from the transfer case? TJRoCStaR TJ Wrangler Technical Forum 1 08-12-2005 04:34 PM
