leaking trans - JeepForum.com
post #1 of 1 Old 04-09-2010, 05:52 AM Thread Starter
daox
swampbutt
daox's Avatar
leaking trans
hey i got a question... could too much gear oil in a trans cause it to leak.. might be a stupid question, i'm thinking yes but wanted to get a few opinions.
I went to check my trans fluid the other day because i noticed a "heavy" leak, by heavy i mean after sitting for 12 hours it may drop once or twice. so as i opened the check hole, maybe a quart of gear oil poored out the side... how it got that in there i don't really have a clue because i didn't fill it up last, it was proply one of my friends, goes to show you that you should never let anyone else fill fluid levels but yourself. but now that i did that and have waited for two days i now do not seen a single leak. has this ever happened before?
I LIKE BEING CALLED A NOOBIE BECAUSE IT SOUNDS LIKE BOOBIE AND THAT MAKES ME GIGGLE!
daox is offline
AX 5 trans. leaking in inside of 95 YJ jaball YJ Wrangler Technical Forum 2 10-14-2009 12:21 PM
trans fluid leaking? cadencedad TJ Wrangler Technical Forum 2 03-06-2009 08:59 AM
leaking trans? jeepinjames20 YJ Wrangler Technical Forum 15 04-17-2008 11:33 PM
leaking trans? sasquachYJ YJ Wrangler Technical Forum 4 03-10-2008 09:22 PM
trans fluid leaking DBraceM20 TJ Wrangler Technical Forum 5 01-14-2007 11:48 PM
