Leaking Steering Box - JeepForum.com
post #1 of 18 Old 11-03-2010, 10:28 PM Thread Starter
MrJohn
Hey, I just bought this Jeep Monday, and I have been learning how to drive stick on it. I haven't taken it off the road at all, just to and from parking lots to learn how to drive stick. I parked it in my dorm parking garage, and I went to it two hours later and there was a fresh leak, directly under the steering box/pitman arm. I saw a post about someone who fixed their steering box, and gave a very detailed write up about it (http://www.jeepforum.com/forum/f11/f...g-box-1088128/). I also saw someone say they used Lucas Power Steering Stop Leak, a liquid that, well, stops the leak. My question is, should I go and do the repair, being new to Jeeps, or should I try the Stop Leak. I guess I could try the liquid, and if it doesn't work, try the repair, I didn't think about that.
There's a picture of where the oil is coming out of.
Any thoughts or ideas?
MrJohn is offline
post #2 of 18 Old 11-03-2010, 10:33 PM
Hbeaudreau
1987 YJ Wrangler
go get one from a durango at a junk yard. Shouldnt cost to much, it will bolt right up and is much stronger then the one on there.
So what if my Yj is 5 years older then I am?
63 Scout 80 - 196 L4, 32 KM1's, SOA
87 YJ- 4.2TBI, Dana 44's, 35 KM2's, SOA
YJ Build : http://www.jeepforum.com/forum/f12/my-87-yj-build-thread-1072026/
Hbeaudreau is offline
post #3 of 18 Old 11-03-2010, 10:56 PM
provinT13
I wouldn't mess around with the stop leak, it's only a temporary solution. The steering gear box isn't too difficult to take off and it would probably be cheaper and easier to do what Hbeaudreau said and get a steering box from a 98-99 Dodge Durango.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #4 of 18 Old 11-04-2010, 12:26 AM Thread Starter
MrJohn
How would it be cheaper? Wouldn't it be around 50 dollars for a steering box from a Durango? I just pulled that number out of the air, I don't know.
MrJohn is offline
post #5 of 18 Old 11-04-2010, 12:33 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
And last I checked, a reman replacement is well over 100, at least around here. The rebuild kit alone is 55ish.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #6 of 18 Old 11-04-2010, 04:46 AM
hdsport
2008 WK
I had the same problem with a leaking steering box...2000 Wrangler TJ.
Solutions are: 1) Replace with a rebuilt one - probably less than $200 w/ core and your time to do it. (OR a new one....more $).
2) Rebuild .... Kits are probably less than $40 at NAPA - and your time to do it. Results are "iffy" I'm told.
So, I tried something that an "old timer" showed me about 40 years ago.
I put about 1/2 oz of brake fluid (NO MORE) into the power steering reservoir. Brake fluid will swell o-rings. I did this - don't add any more than this. I watched my leak decrease in a couple of days and in less tan a week, it was gone.
That was about three months ago. At this time there is NO leaking from my PS gear.
I did this as a personal test....if it didn't work, i would have to replace the steering gear anyway.
This is quick, cost effective and it worked.
So far, so good,
ALSO, FIRST, I put a bottle of Lucas into the PS Reservoir. NO CHANGE in the leak.
.....Called Lucas, sent in the upc & receipt and got a refund.
I will probably use a turkey baster & short hose to pull out about a qt of "old" fluid and replace w/ new fluid one of these rainy days.
Overall. I am satisfied with the results of this test.
If you try it, let us know how it works out.
Thanks.
hdsport is offline
post #7 of 18 Old 11-04-2010, 08:39 AM
kcaverly
At Partsource (canadian parts chain) you can get seals for the steering box, I think one is about 5$ and the other is about 12$. I bought a set when my box was leaking and it was less than 25$ all in.
Kevin
kcaverly is offline
post #8 of 18 Old 11-04-2010, 09:14 AM
bazz
Junk yard box? depending where you're at it should be a lot cheaper then buying a rebuilt one
you can build it on the cheap... but build it right, short cuts will kill you and a busload of church kids
bazz is offline
post #9 of 18 Old 11-04-2010, 11:49 AM
bilwil
1987 YJ Wrangler
HDSPORT
I have the same problem as MRJOHN with power steering on my yj. It was slowed the leak down to a little leak with lucas, but the AT fluid sounds good. I will put that idea away for a leakey day :-)
My wifes ford started the ford PS howl and lucas made it a wimper. Just wonder if some 90 wt. would of worked the same!
Bill,
87, Laredo
bilwil is offline
post #10 of 18 Old 11-05-2010, 09:26 AM Thread Starter
MrJohn
I did Lucas, I got a couple of good reviews from a few friends, and it was cheaper. Put it in yesterday, no leak yet. If it starts leaking, I'll let you know. Thanks for the ideas guys, hdsport, interesting idea.
MrJohn is offline
post #11 of 18 Old 11-05-2010, 12:53 PM
-jb-
I had a durango box leaking bad. Tried lucas junk, didn't work. Replaced it with a YJ box. I will turn the durango box in as a core and get a reman one eventually.
Also the rebuild kits are iffy. If you don't have everything tight and sealed properly, it won't work. I've seen friends try them with bad results and wasted time.
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
post #12 of 18 Old 11-05-2010, 02:48 PM
provinT13
Steering box at junkyard here, $25. That's a low price for a gearbox upgrade that really only includes you knocking out a few bolts and popping the new one in.
This
post #13 of 18 Old 11-05-2010, 11:35 PM Thread Starter
MrJohn
This
This?
MrJohn is offline
post #14 of 18 Old 11-06-2010, 04:12 PM
yabo71
Old Timer
Trying the Old Timer.... trick. I will post in a few days to let ya know if I see an improvement. About 10-15 drops overnight to start...
yabo71 is offline
post #15 of 18 Old 11-06-2010, 07:26 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I rebuilt the box I took out of an '86 XJ, four years ago. It hasn't leaked a bit since then.
$35 for the box with a dropped pitman arm, and $7 for the seal kit.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
TJ Steering box leaking raskull TJ Wrangler Technical Forum 20 07-11-2014 10:13 AM
Steering box leaking from nut on top... firefighter315 YJ Wrangler Technical Forum 1 11-18-2008 01:22 AM
steering box leaking bustedtj TJ Wrangler Technical Forum 7 09-08-2007 09:01 AM
Leaking Steering Box Jeep Sahara TJ Wrangler Technical Forum 5 04-27-2005 05:05 AM
Leaking Steering Box :( Jasonoff TJ Wrangler Technical Forum 3 09-21-2004 03:51 PM
