Leaking fill plug on D35 - JeepForum.com
post #1 of 12 Old 06-22-2005, 07:27 PM Thread Starter
4cylYJ
I looked at my rear diff to day and noticed that gear oil was coming out of the fill plug. Has anybody else ever had this problem. It didn't leak out of it untill I changed the diff fluid in it about three months ago.My jeeps is nearly 10 years old
so I wouldn't be suprised if the rubber plug was a little dry rotted.
4cylYJ is offline
post #2 of 12 Old 06-22-2005, 11:07 PM
jeepfury
Did you try to over fill it? Is it leaking a lot? Like leaving a drips on the bottom of the diff? If it isn't just a little oil on the cover is okay. Maybe if you switched to synthetic that might be part of the problem. I am using royal purple synthetic and have had no leaks though. And if everything checks out then I would just go get a new plug from the parts store.
JOOP
00 Cherokee Classic- Stock
jeepfury is offline
post #3 of 12 Old 06-22-2005, 11:58 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Or you can take it out clean it off, put it back in and then coat the outside of it with a thin layer of that squeeze gasket stuff...you know what I mean.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #4 of 12 Old 06-23-2005, 06:58 AM
blake989
If you put a lift on recently and shimmed the rear axle, you tilted the rear of the differential down a little from the stock position. Yes, mine leaks, it continues to leak because I continue to add fluid to keep it full. Let me know if you figure out a way to stop it.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #5 of 12 Old 06-23-2005, 09:19 AM
Wif
Wif's Avatar
Remove the plug .. clean it up and then just put some RTV around the groove in the plug and replace it in the hole ..
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #6 of 12 Old 06-23-2005, 06:08 PM
Hackle
Hackle's Avatar
I would suggest removing the plug.
Remove the entire D35 from the vehicle.
Replace with a D44 of Ford 8.8.
Throw away old plug.
Works every time for me.
89 YJ Nearly Stock:)
3 link w/ coilovers front. 4 link coil over rear, 39.5" IROC's, Walker Evans Beadlocks, Rear 60 w/spool, Tera Low, Front 60 w/ OX Locker, Warn 9000, & a few others. New 4.0 HO
Hackle is offline
post #7 of 12 Old 06-23-2005, 06:13 PM
pyro9862
Best idea yet.
Or take the drain plug out and put a wrap of teflon tape around it.
pyro9862 is offline
post #8 of 12 Old 06-24-2005, 11:15 AM
acejeep
Originally Posted by pyro9862
Best idea yet.
Hate to tell you the obvious but .............. wind the teflon tape in the opposite direction of the threads so that when you tighten the plug it pulls the teflon into the threads. I'd use 3 or 4 wraps.
Knowledge is what we get from reading the directions.
Experience is what we receive from not reading the directions.
acejeep is offline
post #9 of 12 Old 06-24-2005, 12:13 PM
blake989
unfortunately, my rear diff doesn't have a threaded plug, or even the option for a threaded plug, it has a stupid rubber plunger type thing.
blake989 is offline
post #10 of 12 Old 06-24-2005, 12:15 PM
DrunkPenguin
Threads? We don't need no stinkin threads!! Um, my D35 has a rubber plug.
Mine was leaking and I took it off and put it back on and it stopped. Don't know why but it did. Now it don't leak. You should try it. It might not work on yours but it worked on mine. Not sure why it worked on mine but it did and it doesn't leak and I'm happy. Try it on yours and see if it works on yours like it worked on mine, but it probably won't because there is no reason why it should, but it worked on mine.
John
DrunkPenguin is offline
post #11 of 12 Old 06-24-2005, 02:15 PM
blake989
I'll definitely give that a shot DrunkPenguin. Easy on the caffeine man.
blake989 is offline
post #12 of 12 Old 06-24-2005, 04:35 PM
acejeep
Go to a GOOD hardware store, bring the plug, ask for either a wellnut or an expansion plug. Should cost about half a buck and solve your problem.
acejeep is offline
ox locker fill plug size and fill level? brinoff YJ Wrangler Technical Forum 1 06-14-2010 08:18 AM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
D35 Fill Plug leaking?!? JeSimmers TJ Wrangler Technical Forum 4 04-24-2008 08:15 PM
Rock Crusher fill plug leaking sb127 TJ Wrangler Technical Forum 4 05-20-2007 08:47 PM
