Leaking Axle seal on the front. Should I upgrade the axle to a dana 44? - JeepForum.com
post #1 of 22 Old 02-07-2010, 01:50 AM Thread Starter
MWguy101
I have a 95 Yj, from what I can tell it was the base model. I just got some new 33 in Duratec trires on it, which look great. The mecanic told me my front axle seal was leaking on the front right side. He said we might be able to rebuild the axle or depending on how bad it was, I might need to get a new one.
My questions is this, if I have to replace the axle, can I put a Dana 44 on the front and leave the rear one as the original factory one? If so, besides just swaping out the axles, do I need to change out any other parts suck as the shaft, steering linkage, breaks, etc. or can I leave the rest all factory.
I have a 4 in rough country lift on the jeep. It has a 2.5 l engine.
Any advice woudl be great.
MWguy101 is offline
post #2 of 22 Old 02-07-2010, 02:19 AM
91YJBoy
seal only cost $10 i would just fix it
91YJBoy is offline
post #3 of 22 Old 02-07-2010, 07:24 AM
I8AHUMR
Since you have the 95 you have the larger u-joints which is a plus as far as strength. I've seen estimates saying the HP D30 with the larger u-joints are good up to 35's. I wouldn't use a leaking seal as an excuse to swap a 44 in. Much easier to swap a few parts rather than an entire axle.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #4 of 22 Old 02-07-2010, 07:58 AM
jbeebe
might need to replace the whole axle???? that sounds like a load of bs to me. replacing an axle seal is a pretty standard thing. D-30 Axle Shaft Seal Replacement - 1 it's on a tj but you get the idea.
but to answer your questions. there is no d44 made for our yj's, so we have to get it from another vehicle, such as a wagoneer, or the J-trucks. all of which require a certain amount of modification to reposition the spring perches, shock mounts, etc.
Another point is that your rear axle the d35, is much weaker than the d30 to begin with, so if you go d44 in the front, and remain d35 in the back, it would just be a little ridiculous haha. the d35 can't handle more than 33" tires (some would argue it can, but the general consensus is this).
so to sum it up. replacing an axle seal for a mechanic is a routine job, and the seal is cheap. it's really not that big of a deal, don't let the mechanic take you, if he gets into the axle and says something like "yea this seal is too bad, we're gunna need a new axle", talk to us first!!!!!!!
jbeebe is offline
post #5 of 22 Old 02-07-2010, 08:56 AM Thread Starter
MWguy101
Thanks for the link that is really helpful. This looks like its going to be a fun project.
MWguy101 is offline
post #6 of 22 Old 02-07-2010, 09:10 AM
jeepinmichguy_
no sense un upgrading a hp 30 to a 44 imo.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #7 of 22 Old 02-07-2010, 09:35 AM
jbolty
jbolty's Avatar
Check for play in the u-joint and unit bearing on that side. One of those can go bad which creates enough movement in the axle to wreck the seal. Either one is a fairly easy fix and not too expensive, even cheaper if you get junkyard parts.
otherwise swappping in the right side seal costs about $10 in parts.
jbolty is offline
post #8 of 22 Old 02-07-2010, 09:39 AM
bigbelman2009
never go back to that mechanic, sounds like he's tryin to rip you off
bigbelman2009 is offline
post #9 of 22 Old 02-07-2010, 09:39 AM
jbeebe
there are some other tools that people rigged up to seat in the seals, just do a search or start a thread for ideas.
jbeebe is offline
post #10 of 22 Old 02-07-2010, 10:33 AM
ritjobbie
FYI: I have a 1995 but I have the smaller joints. Only some (or most?) 1995 YJs had the larger joints.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #11 of 22 Old 02-16-2010, 05:05 PM Thread Starter
MWguy101
How hard is the axle seal to replace? I am getting a price range from mechanics from $350-$500. The part it self is only $10 at advance auto parts. One mechanic told me you need a special tool to do it. Its seems like a lot of money to install a $10 part.
MWguy101 is offline
post #12 of 22 Old 02-16-2010, 05:13 PM
jbolty
jbolty's Avatar
If you have a lift, proper tools along with experience in this particular job it would take about 1-2 hours. Maximum.
Doing it while laying under the jeep in the dark with a home made seal drive may take longer. Not sure what your time is woth but $500 is robbery.
jbolty is offline
post #13 of 22 Old 02-16-2010, 05:19 PM
purplepig
I agree. I had a mechanic tell me my rear diff was trashed when my seal was leaking. I replaced the seal about 5 months ago and no problems. Just check for play in the u joint like someone else said. oh yea... make sure the yoke doesn't have grooves in it, or it will make the seal leak again.
purplepig is offline
post #14 of 22 Old 06-16-2011, 03:44 PM
DocMojave
I had the exact same experience at Orange County Motorsport. My passenger side seal has failed 2X since the original repair 3 months ago. I'm not even driving off road.
Isn't there a more permanent fix?
Never Mistake Kindness for Weakness. What is desired in a man is kindness, And a poor man is better than a liar.
DocMojave is offline
post #15 of 22 Old 06-16-2011, 04:26 PM
Alabamaranger
Since we have 2 Jeeps, we bought that special seal tool installer ($45) so you don't waste 3 seals trying to pull one in. With the tool, the first seal goes in perfect less than 1 minute. As stated, be sure tio check for play in the bearing for the inside axle shaft. Otherwise if that inside axle shaft is wobbling due to a bad bearing, that outer axle is going to wobble too, which will make the seal to leak.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
Dana 44 axle seal leaking Bigsam TJ Wrangler Technical Forum 22 10-16-2013 01:37 PM
front axle seal leaking? spizzy10 TJ Wrangler Technical Forum 13 08-10-2010 11:56 AM
Leaking front axle seal Mud-n-Beer YJ Wrangler Technical Forum 32 11-15-2009 08:44 PM
Dana 35 Outer Axle Seal Still Leaking, HELP? longboardtim YJ Wrangler Technical Forum 4 05-05-2008 10:39 PM
dana 30 axle tube seal upgrade bailey TJ Wrangler Technical Forum 4 11-01-2004 10:29 AM
