Leaking! - JeepForum.com
post #1 of 10 Old 04-24-2002, 05:52 PM Thread Starter
cjud4x4
cjud4x4's Avatar
Leaking!
Gotta question guys! Whenever it rains hard (which it did today), my passenger side floorboard resembles a small pond.The only place I think the water can be coming from is the vent grate on by the hood. If anybody has, or had this problem and fixed it, any suggestion would be most appreciated.
95 YJ
K&N, 1" Body, Cobra CB, don't know whether to SOA of SL.
"Get to Jeepin, or get out"
cjud4x4 is offline
post #2 of 10 Old 04-24-2002, 06:09 PM
nels666
I'm having the exact same problem om my '95.
nels666 is offline
post #3 of 10 Old 04-24-2002, 06:19 PM
Colby Bruce
My '93 YJ did the same thing. There is a drain tube coming out of the vent box in front of the windshield. The tube comes off the firewall on the passenger side. Mine was full of trash (pine needles, tulip poplar seeds, etc.). Squeeze the bottom of it and shake the trash out. When the vent area fills with water it drains in on your floorboard through the fresh air outlet on the passenger side.
Colby Bruce is offline
post #4 of 10 Old 04-25-2002, 03:46 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Well Said! <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #5 of 10 Old 04-25-2002, 06:10 PM Thread Starter
cjud4x4
cjud4x4's Avatar
Thank you for the advice. It is much appreciated.
95 YJ
cjud4x4 is offline
post #6 of 10 Old 04-29-2002, 01:19 PM Thread Starter
cjud4x4
cjud4x4's Avatar
Well, the tube was totally clean. Does anybody have any other suggestions. Any?
95 YJ
cjud4x4 is offline
post #7 of 10 Old 04-29-2002, 01:36 PM
JeepBeep
I got a leak from my soft top that drips in right past the dash and onto the floor, water gets in where the end of the door/and windshield meet the soft top (up by the roll bar)...not sure if thats the case w/ yours.
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #8 of 10 Old 04-29-2002, 01:51 PM
Dan Morera
Dan Morera's Avatar
I know this might be silly but if you guys still have your carpets on you might want to check under it, my Jeep had a drain hole open and the water was getting in from under my Jeep, I don't know why it wouldn't come out the same way,
Just my 43.25 colones (about $0.02)
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
post #9 of 10 Old 04-29-2002, 08:44 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
My Jeep also leaks pretty bad into the interior .. and I found that most of the leak was between the windshield and the hard-door. I think that replacing my windshield hinges may fix part of the problem, and possibly some sticky-back foam weather stripping will fix it totally.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #10 of 10 Old 05-08-2002, 09:38 PM
nels666
Hey cjud4x4,
Have any luck yet?
nels666 is offline
Leaking AX-5 EJames1226 YJ Wrangler Technical Forum 8 02-20-2008 04:48 PM
oil now leaking--need help! jsr86 TJ Wrangler Technical Forum 1 02-15-2008 01:38 PM
AX-15 leaking Vetteman TJ Wrangler Technical Forum 0 03-03-2007 02:21 PM
SYE Leaking? Viet15philong TJ Wrangler Technical Forum 15 08-10-2005 09:18 PM
leaking oil but from where detroitwhat? YJ Wrangler Technical Forum 4 04-30-2004 09:47 PM
