Leak on my 95 Wrangler. Help? - JeepForum.com
post #1 of 9 Old 06-01-2013, 06:29 PM Thread Starter
JeenBarrett
My first post here, I hope I can get some help with this. I very recently purchased my first car, a 95 Jeep Wrangler YJ. Today when I went to go out I saw a big puddle in my driveway under the front right wheel. Not ON the wheel, but leaking from somewhere right next to it. It doesn't look or smell like oil and the anti freeze overflow is on the left side so it cant be that. I'm afraid to drive it for risk of a more serious issue. Any ideas on what it could be?
JeenBarrett is offline
post #2 of 9 Old 06-01-2013, 06:32 PM
gunshw301
The heater core hoses go through the fire wall right there, that's my guess. But you say it does not look or smell like antifreeze, so maybe not.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 9 Old 06-01-2013, 06:45 PM Thread Starter
JeenBarrett
For all I know it could be antifreeze, I just followed the overflow hose back and it was on the opposite side but maybe there is another hose there on the right. But I checked the radiator and it was full to the brim with antifreeze/coolant so I'd just have to guess its not coolant. The liquid had a sortof orangey tint to it like oil but I'm honestly clueless. I'm no mechanic :/
post #4 of 9 Old 06-01-2013, 08:18 PM
brzehentmaier
brzehentmaier's Avatar
Is the leak right on the inside of the tire? Could be brake fluid. Mabee a caliper or a brake line. Check your master cylinder for fluid level. You don't want to drive away with no brakes. On a lighter note you bought a Jeep not a car. Jeeps are not cars they are "JEEPS" and money pits. I think I only need a few more new parts till mine is new again. Welcome and welcome to the biggest addiction you will ever have. Had my first one at 20 and now 25 years later I'm on my 5th one. Just can't get the YJ's out of my system and probably never will. You will be totally hooked after your first ride topless and doorless and romping through the mud.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #5 of 9 Old 06-01-2013, 09:24 PM Thread Starter
JeenBarrett
Bernie
Haha, yeah its weird calling it a ''car'', I always correct my friends and tell them no, it's a Jeep, not car . But yeah anyways, that's exactly where the fluid was. All over the inside of the wheel well and tire. As well as all over the place around it. Thanks for the info, I'm pretty sure that's exactly the problem. Now I need to figure out why its coming out. Yeah I love YJ's. I love the square headlights and military look. OD green paint job this summer I hope! I took it off roading the 3rd week I had it. no doors top down. Filled the cab with water lol. It was awesome (those drainage plugs come in handy) Thanks a bunch!
post #6 of 9 Old 06-01-2013, 09:54 PM
Turp
A bit off-topic but, being up north, make sure you wash the winter road salt off from the undercarriage and inspect it regularly to stay ahead of rust issues. Wranglers have plenty of spots and crevices to hold salt. FWIW-while they do need a part or two occasionally, they're relatively simple compared to other vehicles and very reliable. Beyond my typical Honda and Toyota choices, Jeep YJs and TJs are definitely on my recommended list.
Turp is offline
post #7 of 9 Old 06-01-2013, 09:55 PM
brzehentmaier
Is the fluid real stinky? Mabee a front axle seal then. Could be gear lube. It's usually dark and stinky unless it's new then it's just clean and stinky. Check the fluid in your brakes master first though. I'm betting on the brake line being broken though I've had both problems in the past and they both left a puddle on the ground under the tire and wet all over the inside of the tire. If the fluid is gone in one of the masters bowls(I think the front one, can't remember) then you know it's the brakes. Otherwise i'd say axle seal. I've done them myself and also at the shop. It should cost around $150.00 to get done at a shop[ or $4.50 for the seal and a couple broken knuckles if done yourself. Good luck and post up your findings.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #8 of 9 Old 06-01-2013, 09:58 PM
brzehentmaier
Added note: Geal lube is thick and brake fluid is thin and runny.
1995 Rio Grande
A Work In Progress
A new begining
post #9 of 9 Old 06-03-2013, 04:02 PM Thread Starter
JeenBarrett
Found out what it was. It WAS the return line for the coolant/antifreeze. The return line runs right next to the right front tire and the molded tubing was split on the hose clamped end so I cut the split part then pulled the rest 2 inches onto the metal spout and clamped it shut
front end , Leaking , oil
