leak at front of transmission and back of engine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > leak at front of transmission and back of engine
AMP Research Powersteps - A Morris 4x4 Center PromotionCrawler Conceptz at JeepHut.comTime To Save On Yukon Lockers!
Unread 07-18-2013, 04:01 PM   #1
Fellows45
Hey guys,
I just finished servicing my 89 wrangler, and noticed a leak at the front of my transmission. It's not the valve cover gasket, because I just replaced and tightened to spec.
also, I just replaced the trans fluid a few weeks back and the fluid that you see on the starter is pretty new which makes me think its the trans that is leaking. I changed the oil 1500 miles ago and there is fully synthetic 10w-30 in both.
much thanks,
Fellows
Fellows45 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 04:07 PM   #2
Gage56
Valve Cover??
1992 YJ
Gage56 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 04:08 PM   #3
XJ93
Just because you tightened it to spec doesn't mean the valve cover isn't leaking. That looks awfully high up to be trans fluid beside the fact that it's more on the engine block than the bell housing. I would spray it all down and watch to see where it leaks from, and I'll wager a dollar it's the rear of the valve cover.
XJ93 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 04:21 PM   #4
Brshpile
Check the plug that the oil gauge goes into. It is right behind the valve cover.
Brshpile is offline   Reply With Quote Quick reply to this message
Unread 07-18-2013, 04:34 PM   #5
pasinbuy
X2 Clean it, let it dry and watch it. Feel around for leaks when cool.
pasinbuy is offline   Reply With Quote Quick reply to this message
leak , Leaking , transmission leak
