leafs v coils - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > leafs v coils
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 06-15-2014, 08:57 AM   #1
1morecj
leafs v coils
how common is it to switch from leaf springs to coil? the PO had a coil lift kit installed on a '93 YJ I just got. pros? cons? thx
1morecj is offline   Reply With Quote Quick reply to this message
Unread 06-15-2014, 09:24 AM   #2
89yjislanderr
it's not super common. people do it. it's not crazy. better ride, potential for better flex. of course, then you need sway bars and disconnects and all that business if you have coils. I like leafs better.
89yjislanderr is offline   Reply With Quote Quick reply to this message
Unread 06-15-2014, 11:35 AM   #3
Carlos14
Coming from Someone who had both, on the same jeep, I can say that leafs are easier. Coils involve a lot more than just the springs like leafs. The coils ride better on the street and can flex better than any SUA leaf setup. However I am SOA up front and it flexes just as good as the rear coils, if not better.
If you have a coil setup already then you should be pretty solid both on and off road.
Luck Favours The Prepared
Carlos14 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2014, 11:42 AM   #4
YJ4LIFE
Not common unless someone has and old coil conversion kit. most coil conversions are on hardcore custom setups as they are not cheap to do right and usually cost as much as a used YJ
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote Quick reply to this message
Unread 06-15-2014, 04:13 PM   #5
fratis
fratis's Avatar
There were never any conversion kits made that worked better then the potential of leaf springs.
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote Quick reply to this message
Unread 06-16-2014, 07:57 AM   #6
LilViper95
I swapped to coils when I built my jeep. My frame was trashed, found a TJ frame and modified it to work. Front is all off the shelf tj parts. Rear is a custom triangulated mid arm 4 link. I have owned a pile of yj's, the coil conversion was the best thing I ever did!
LilViper95 is offline   Reply With Quote Quick reply to this message
