Leaf Springs and the Axle - JeepForum.com
post #1 of 8 Old 04-13-2010, 04:34 PM Thread Starter
Tobynt89
I've noticed on some Jeeps the leaf springs are a lil diff than mine. I've wondered if it's just the YJ-way or what.
But the axle is above the leaf springs. I've seen some where the axle is sitting below the leaf spring.
To me, it makes sense for the axle to be below the leaf springs. But I'm just wondering, and wanting to see what people think, and have you guys done anything about it.
Plus, my leaf springs are getting old, 20 years old, so they need replacing soon. So whenever I go to replace 'em how should I put 'em back in.
Open in any opinions, please post. :]
Thanks :]
Tobynt89 is offline
post #2 of 8 Old 04-13-2010, 04:39 PM
bgredjeep
1987 YJ Wrangler
Not sure what you are looking for. Search SOA and SUA and I'm sure you'll find lots of info related to the different suspension configurations people are using. There is also some info in the FAQ.
bgredjeep is offline
post #3 of 8 Old 04-13-2010, 05:00 PM
timatoe
timatoe's Avatar
The stock configuration for all YJ's was to have the springs under the axles. Many people do what is called an SOA or (Spring Over Axle), there are a good deal of benefits to going SOA but you should know that it is not simply welding some new spring perches above the axle. There are a number of things that have to be addressed, like a Slip Yoke Eliminator for the transfer case, which brings the need for a new rear drive shaft, longer brake lines, longer shocks, addressing steering related issues, there's a lot to be done and it's not real cheap. Read, read, read, that's the best advice I can give you on that.
timatoe is online now
post #4 of 8 Old 04-13-2010, 05:04 PM Thread Starter
Tobynt89
To make it shorter and less complicated-
My leaf springs are under my axle, are they supposed to be there? I've seen it differently in other Yj jeeps (leaf springs over axle). If I replace them, (which I am very soon since they are 20 yrs old) should i put them over the axle instead?
thx
Tobynt89 is offline
post #5 of 8 Old 04-13-2010, 05:08 PM
NateWithoutBeer
That's the stock configuration, they're supposed to be that way. If you replace your springs and leave them that way it's a fairly easy thing to do.
As bgred mentioned, there's no easy answer to whether you should go SOA (springs over axle) or stay SUA. Google it and search the forums for SUA and SOA to get the pros/cons and an idea of the process.
NateWithoutBeer is offline
post #6 of 8 Old 04-13-2010, 05:46 PM
notmyj
The YJ's came from the factory with the springs under the axle (SUA). Lift springs, or even factory replacemnt springs are intended to put on in the same way (SUA).
If you want to put the spring on top of the axle (SOA), it can be done, and will give close to 6" of lift on factory springs. As well as a better ride (as compared to lift springs) and more flex. However, doing an SOA conversion is not cheap, easy, or quick. There are a lot of things that need to be done to do it safely. Your driveline angles will need to be adressed with a slip yoke eliminator (SYE), a new CV drive shaft will need to be made fro use with the SYE, an anti wrap bar for the rear axle is a must, and steering correction for the front axle will need to be done.
This will require a decent amount of knowledge and skills to do, as there is a lot of welding that will need to be done. When going SOA you will be doing it to fit bigger tires. The D35 rear axle doesn't like 33" tires and will break easily. So you will want to consider a ford 8.8 rear axle swap at the time. Since your going with bigger tires and a stronger axle, you should regear the axles too since you will have them out. 4.88 is very common for 35" tires.
Just what wrote above will run you close to $2k. More or less depending if you can do the work yourself.
Look in the FAQ section at the top of the YJ Tech forum. Under suspension, there is a great write up on doing an SOA and links to other SOA related stuff, including why not to do it on the cheap.
Get comfortable, and have a seat. You will want to do hrs of reading before you pick up a wrench. The more knowledgable people here have made some very costly mistakes, and have posted them here so that others can learn from them. Head the warnings posted by others and do your research. It will pay off big dividens if you do.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #7 of 8 Old 04-13-2010, 05:58 PM Thread Starter
Tobynt89
Wonderful!
I'm just gonna stick to factory ways..
Thank you guys for posting!
Tobynt89 is offline
post #8 of 8 Old 04-13-2010, 06:57 PM
DivineKaos
You do not require a SYE or new axle for SOA.
It is always a good idea to replace the D35- but that can be done for around $120 for an 8.8 around here.
My buddy is SOA, with a D35 (he has an 8.8 already waiting for the d35 to break- he has been waiting 3 years) he wheels hard, and no SYE. No vibes, and no issues with Ujoints. No body or MML either. Just a tcase drop. Depends on the jeep.
SOA is a good conversion, just do it safely.
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
5 Leaf Vs. 6 Leaf YJ springs for SOA application yjcrawler YJ Wrangler Technical Forum 5 11-21-2009 03:27 PM
Removing a leaf from leaf springs jonlb YJ Wrangler Technical Forum 14 04-12-2009 01:59 PM
removing 1 leaf from leaf springs skipilot YJ Wrangler Technical Forum 2 02-25-2009 02:37 AM
Leaf springs to the top of the axle, will this work? JEEPREBEL YJ Wrangler Technical Forum 4 11-12-2004 10:33 AM
Front leaf springs same as Rear leaf springs? JayJEEPguy YJ Wrangler Technical Forum 5 12-02-2003 11:53 PM
