Leaf Spring shifted - JeepForum.com
post #1 of 8 Old 04-09-2010, 06:36 PM Thread Starter
spawnofsatan
Leaf Spring shifted
My LR Bottom Leaf (short one) has shifted and no longer straight Can I adjust them by just loosen the U bolt Nut and straighten them out or do I need to Jack the Jeep.
spawnofsatan is offline
post #2 of 8 Old 04-09-2010, 06:45 PM
Burnerman
Burnerman's Avatar
I'd use a block of wood and a hammer and try to knock it back inline. If it's shifted way out of place I'd get a new center bolt and U bolts pull the pack and redo it.
Actually if it was me I'd call BDS and have them send me my free replacement spring pack and u bolts.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 8 Old 04-09-2010, 07:01 PM
joshbaker92yj
yea me to gotta love great customer service.
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
post #4 of 8 Old 06-02-2010, 09:18 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
What causes them to shift?
Both sides in the rear of my Jeep did this. I noticed it today. I've only had it on the road a week so the leafs are new. I know I torqued them to specs and used thread lock on the ubolt nuts so I'm sure they haven't loosened up.
I used a hammer and had no trouble getting them back in line. I was going to start a new thread but did a search and found this thread.
I would like to know the cause and the proper fix. Maybe add an extra wrap that includes the lowest, shortest leaf?
-John-
johnboy68 is offline
post #5 of 8 Old 06-02-2010, 09:54 PM
fratis
fratis's Avatar
its all in how you define a "problem." mine are often out of line front and rear as ive modified the clamps to allow maximum leaf freedom. if there are no adverse effects then is it really something to fuss over and spend time on.
fratis is offline
post #6 of 8 Old 06-02-2010, 10:17 PM
moonshinefuel
I can tell you mine shift too. I really don't think too much of it.
moonshinefuel is offline
post #7 of 8 Old 06-03-2010, 03:56 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Okay, thanks. I'll try not to worry about it.
It's probably due to not having a rear track bar and doing some wheeling this past weekend. At one point I had one rear tire on a rock and the other in the air.
-John-
post #8 of 8 Old 06-03-2010, 05:15 AM
Louie4
My Black Diamond springs have a small leaf on the bottom that is only held in by the spring pin and the spring plate. They tend to shift due to the flexing the springs. I usually just get a hammer and knock them straight.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 08:32 PM
Leaf spring help dompaz YJ Wrangler Technical Forum 4 11-06-2005 03:51 PM
HELP can't get a leaf spring out!!!!!! oct7brian YJ Wrangler Technical Forum 12 07-29-2005 11:57 PM
Leaf spring add on kryj YJ Wrangler Technical Forum 0 08-02-2004 07:34 PM
leaf spring whril YJ Wrangler Technical Forum 1 07-27-2003 06:43 PM
