Leaf Spring replacement help - Page 2 - JeepForum.com
post #16 of 21 Old 10-08-2013, 08:45 AM
Rproject
1987 YJ Wrangler
Originally Posted by superj View Post
how would the different size tires change the distance of the axle form the t-case?
The larger the tire, the higher the center of the axle is (AKA increased ground clearance) thus changing the angle between the output of the transfer case and the input of the axle.
Oh, and BTW, I was running a 6 degree shim on the Rancho lift. It was even worse before I put in the shims.
As I look back at both lifts, all things were equal except the tire size. Same lift height, same axles, same driveshafts, same degree shim (OME has a shim on the spring from the factory), different tire size. One needed the drop, one did not. Logic would dictate that the tire size changed the geometry.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #17 of 21 Old 10-08-2013, 09:48 AM
AmmitOsiris
AmmitOsiris's Avatar
Originally Posted by Rproject
The larger the tire, the higher the center of the axle is (AKA increased ground clearance) thus changing the angle between the output of the transfer case and the input of the axle. Oh, and BTW, I was running a 6 degree shim on the Rancho lift. It was even worse before I put in the shims. As I look back at both lifts, all things were equal except the tire size. Same lift height, same axles, same driveshafts, same degree shim (OME has a shim on the spring from the factory), different tire size. One needed the drop, one did not. Logic would dictate that the tire size changed the geometry.
I don't think tire size changes it at all. It just puts te axle higher, out springs are what makes the driveline angles.. Hell I could put 44 in tires and my driveline angle would be the same. Please somebody correct me if I am wrong.
Sent from Peggy's office
AmmitOsiris is offline
post #18 of 21 Old 10-08-2013, 09:58 AM
flipit
Originally Posted by Rproject View Post
Your brake lines can be relocated. Anticanman has a nice relocation write up that works well.
http://www.jeepforum.com/forum/f12/f...d-yjs-1421561/
flipit is offline
post #19 of 21 Old 10-08-2013, 10:04 AM Thread Starter
Cuesoccer24
Rproject...where can I find that write up?
Cuesoccer24 is offline
post #20 of 21 Old 10-08-2013, 10:09 AM
Rproject
1987 YJ Wrangler
Look 2 posts up
1996 White ZJ
Rproject is offline
post #21 of 21 Old 10-08-2013, 10:53 AM Thread Starter
Cuesoccer24
Thank you
