I recently bought ruff stuff 6" boomerang shackles for the front of the heep and I started noticing at low speeds on a hill or incline when I'm turning, the front leaf springs make a popping/clunking noise. I tightened down the fasteners from the shackle to the leaf spring to I believe 80 or 90 ft-lbs. Seems like they are to tight but the nuts aren't threaded onto the bolts very far. Any suggestions?
Stock torque calls for 100 ft lbs.
The flex comes from the bushing, not the bolts.
The sleeve is there so it can't be over-tightened unless it's so tight the sleeve is being crushed.
Did you recently install OME?
If so, what bushings/sleeves did you use?
The OME springs are a bit thinner than other springs so if the original sleeves are used, they need to be cut down @ 1/4'' ish
I put my hand on the area and felt it while my buddy was moving the wheel. Can't be drive shaft, I took it out a year ago (still need to re-gear the front)
I was thinking about the axle shaft u-joints. They turn with tires and can cause some binding in turns if worn out. Any chance you could post some photos for us to look at?
Man!! I was looking all of the Internet for right direction to install, everyone had a different opinion. I will flip them around and get new center bolts. Thanks for the help!
Not only will you need the center bolts (4", grade 8, 1/2 inch blots with Nylock nuts) you will need a spacer tube.
You can make your own spacer tube out of some thick-walled metal pipe. I found a 2-foot section of 3/4" OD / 1/2" ID metal tube at the local McFadden-Dale store for about $10. (sorry I removed the sticker so no part number)
Cut the tube to exactly 3" and it will keep the sides from wobbling in on your stabilizer bolt. If you do not have the means to cut the pipe, PM me and we can work out something.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
