Leaf spring hardware - JeepForum.com
post #1 of 15 Old 01-23-2014, 02:43 PM Thread Starter
bpounds
bpounds's Avatar
Been searching, and can't find the definite answers. I'm ordering springs for the YJ and I want to replace all the bolts in the shackles and the frame eye. I'm expecting to have to cut some bolts to get them out, but even if I don't I would like new bolts and bushings.
What bolt diameter and pitch for the shackle end?
What bolt diameter and pitch for the frame eye end?
Not worried about length, I can easily measure that, and I know it can vary depending on shackle thickness.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #2 of 15 Old 01-23-2014, 03:06 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
9/16". Thread pitch shouldnt matter as long as you get nuts to match.
Randonexplosion is offline
post #3 of 15 Old 01-23-2014, 03:07 PM
Jeepsr4me
You dont need pitch. Cause if you replacing the bolt, the nut also should be changed.
Jeepsr4me is offline
post #4 of 15 Old 01-23-2014, 03:17 PM Thread Starter
bpounds
bpounds's Avatar
For which? I see references to the shackle end being different than the end attached to the frame.
Correct, I just wondered if stock was course or fine thread.
Bill
bpounds is offline
post #5 of 15 Old 01-23-2014, 03:23 PM
1320yj
If you are getting shackle bolts get greasable ones. They sell them on EBay
1995 2.5 5 Speed SOA +2.5 rough Country lift, High steer kit , 33x12.50 Mud Rovers
1320yj is offline
post #6 of 15 Old 01-23-2014, 03:28 PM
Randonexplosion
Deplorable
After a quick search Mr. Bolty says 1/2" on shackle end.
post #7 of 15 Old 01-23-2014, 03:42 PM
87duker
9/16 towards center and 1/2 for shackle end. Just put new ones in mine.
87duker is offline
post #8 of 15 Old 01-24-2014, 08:29 AM Thread Starter
bpounds
bpounds's Avatar
I crawled around under Mauser and confirmed the bolts I will need.
Frame spring mounts are 9/16-12NC and need 4" length.
Upper and lower shackle bolts are 1/2-20NF and need 4.5" length. That length will work with 3/8" thick shackles.
Ordered all that including washers and nylock nuts from McMaster. All grade 8.
Bill
bpounds is offline
post #9 of 15 Old 01-24-2014, 04:13 PM
rstoltenberg1
Where did you get your leafs? My stock ones are sitting flat and there are so many options and stuff available, with different price's everywhere.
rstoltenberg1 is offline
post #10 of 15 Old 01-24-2014, 04:16 PM Thread Starter
bpounds
bpounds's Avatar
I'm going with Zone Offroad kit.
Bill
bpounds is offline
post #11 of 15 Old 01-24-2014, 05:15 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
4" wont hit the nylon if you use nylock nuts and 3/8 shackles. ask me how I know. I used 1/2"x4 1/2" with I believe 13 thread count. the stock ones were a finer thread
Granted I used g8 washers on both sides too
-April '14- YJoTM- June '15
The_Goob is online now
post #12 of 15 Old 01-24-2014, 06:21 PM Thread Starter
bpounds
bpounds's Avatar
I'm not sure if you are disagreeing with my measurements, or just confirming. But I noted 4" for the fixed frame end. Shackle thickness is irrelevant on that end. On the shackle end, you want 4.5" long, as I noted. So we agree.
Bill
bpounds is offline
post #13 of 15 Old 01-24-2014, 07:03 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I just read it wrong then. carry on :P
post #14 of 15 Old 02-06-2014, 01:39 PM Thread Starter
bpounds
bpounds's Avatar
I don't want to cause someone issues, so I'm going to edit my post here. After installing my lift with 3/8" thick shackles, I found that these lengths worked, but it would have been better if both sizes had been 1/4" longer. Usually you can't find these in 1/4" increments, so that means they should be 1/2" longer. You could cut 1/4" off if you wanted. I wouldn't.
I used the lengths posted above, and it worked, but I had to omit washers on both sides of the frame mounts, and I had to omit the washer on the head side of the shackle bolts.
Next time I would go with this:
Frame spring mounts are 9/16-12NC and need 4.50" length.
Upper and lower shackle bolts are 1/2-20NF and need 5.00" length. That length will work with 3/8" thick shackles and SAE washers on both sides of each bolt.
Bill
bpounds is offline
post #15 of 15 Old 02-06-2014, 04:50 PM
kingcat400
my frame side bolts were metric on my 93. 16mm i think
kingcat400 is offline
