Leaf Spring and Engine Start problem - JeepForum.com
post #1 of 3 Old 10-08-2001, 05:27 AM Thread Starter
bonehead99
bonehead99's Avatar
My driverside leaf spring is not sitting right the shackle end is fine but the rear is not tight around the bushing. Their is about a 1.5" to 2" gap. Now the starting problem is the relay inside the box in front of the battery that is for the starter. The relay is not drawing over when you turn the key. I replaced the relay and it still does it.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 3 Old 10-08-2001, 07:26 AM
glm 87 wrangler
cant help with the leaf spring,but for the relay you may want to check the wires going to it make sure they are fairly clean,try taking a volt meter to it for power if you cant check your ignition fuse and others in your fuse block.You could try to jump the starter but if you never done that before dont find some one to check it out for you.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 3 Old 10-08-2001, 08:12 AM Thread Starter
bonehead99
bonehead99's Avatar
I took the top off the relay and used a screw drive to push it over with the key in run position it starts everytime. The ignition fuse under the dash is good. Could the key switch in the steering column be bad? It won't start with the remote starter either.
YJ Rear Leaf Spring Problem RicksYJ YJ Wrangler Technical Forum 11 03-06-2008 12:21 PM
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 09:32 PM
Engine start problem jarsh TJ Wrangler Technical Forum 1 05-28-2007 09:01 PM
Leaf spring help dompaz YJ Wrangler Technical Forum 4 11-06-2005 04:51 PM
Leaf spring add on kryj YJ Wrangler Technical Forum 0 08-02-2004 08:34 PM
