leaf over kit? - JeepForum.com
post #1 of 117 Old 03-13-2014, 09:49 AM Thread Starter
Cowboy91
leaf over kit?
Hey y'all I was just curious as to what y'all think about the Leaf Over Kit. So you can put the leaf springs going over the axle instead of going under. I was told that it makes it ride much nicer on road. And it gives you more lift. Are both of those things true? Can it really make the ride Mich nicer for on road and will it really give you more lift?
Cowboy91 is offline
post #2 of 117 Old 03-13-2014, 10:04 AM
jsawduste
2006 YJ Wrangler
Well gol darn. Now thar`s a good idear.
I`m out.
jsawduste is offline
post #3 of 117 Old 03-13-2014, 10:09 AM
Jeepsr4me
take a look at your front steering, now picture those springs on top..... Thats the biggest issue you will have
Jeepsr4me is offline
post #4 of 117 Old 03-13-2014, 10:11 AM
SeniorVerde
It's a common mod, there's some acronym for it. Tube Inverse Transfer Setup, or something like that.
Sometimes, you don't even need a kit. I'm going to go search the acronym and see if that's right.
SeniorVerde is offline
post #5 of 117 Old 03-13-2014, 10:27 AM
rykemc
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #6 of 117 Old 03-13-2014, 10:51 AM
40dog
Leaf it alone.
Keep your nose to the wind and your eye upon the skyline
40dog is offline
post #7 of 117 Old 03-13-2014, 11:20 AM
jsawduste
2006 YJ Wrangler
Anther good topic is CanUNotTouchit.
Try that search term and see what comes up !!
post #8 of 117 Old 03-13-2014, 11:26 AM
jeepguy85
1987 YJ Wrangler
Originally Posted by jsawduste
Anther good topic is CanUNotTouchit. Try that search term and see what comes up !!
I will search it right meow.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #9 of 117 Old 03-13-2014, 11:33 AM
1320yj
Its called Spring Over Axle or SOA. It in itself doesnt change ride quality however comparing it to other ways to lift a Jeep YJ it gives a better ride. As far as steering goes under normal driving (not extreme flexing) modifications to the tie rods and steering knuckles arent needed. The op asked a legit question all that abuse wasnt needed.
1995 2.5 5 Speed SOA +2.5 rough Country lift, High steer kit , 33x12.50 Mud Rovers
1320yj is offline
post #10 of 117 Old 03-13-2014, 12:12 PM
40dog
We told him to stay away .now you let out those three little letters SOA. Dont you know " the owl is not what it seems.." loa < soa. loa=sos
40dog is offline
post #11 of 117 Old 03-13-2014, 12:20 PM
roadyrob
1987 YJ Wrangler
the steering only has to be modified if you want to be safe driving it.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #12 of 117 Old 03-13-2014, 12:23 PM
1320yj
WRONG
If the conversion is done paying attention to caster angles and the front end is aligned properly they will drive perfectly safe. Mine Does
1320yj is offline
post #13 of 117 Old 03-13-2014, 12:24 PM
JeepinJeremy
You can flip your rear axle over using the factory perches and an added bonus making it a high pinion 35.
JeepinJeremy is offline
post #14 of 117 Old 03-13-2014, 12:29 PM
jeepguy85
1987 YJ Wrangler
This is getting interesting.....
post #15 of 117 Old 03-13-2014, 12:33 PM
youngjeepr
You obviously haven't done a SOA or ridden in one. The ride quality with stock springs SOA is much better than any SUA setup I have seen or ridden in. Also you get much more flex out of a SOA setup. The OP did ask a legit question... That has been asked a thousand times before. If he would have done a search before posting he would have found his answer.
The steering needs to be redone, you will need an SYE, longer brake lines, longer shocks, a better rear axle (assuming you have the d35) if you plan on running bigger tires than 32s, at least a new rear cv shaft, and you will need to address axle wrap.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
