Late, last minute advise, please! - Page 2 - JeepForum.com
post #16 of 22 Old 04-07-2010, 07:19 PM
Burnerman
Burnerman's Avatar
Heat... It works wonders on the torx body bolts.. Oh and valve lapping compound on the bit help keeps it from stripping. To drop the windsheild you just need to remove the 4 spreaderbar bolts and the 2 larger torx bolts on the dash. Oh and the sunvisors!
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #17 of 22 Old 04-07-2010, 07:23 PM Thread Starter
RockWoRM
RockWoRM's Avatar
You're a hair late on your post. but what is 'lapping compound'? never heard of it.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #18 of 22 Old 04-07-2010, 07:36 PM
K4KAS
After you turn valves on a lathe, or new valves even, they have a "rough" edge. You take this compund, smear it on the valve and the seat, suction cup a wood handle to the top of the valve, and spin the valve back and forth in its seat. Kind of like trying to start a fire. It mates the valve to its seat. Almost the consistancy of rubbing compound for paint.
K4KAS is offline
post #19 of 22 Old 04-07-2010, 09:23 PM
joshbaker92yj
u can also use anti seize for bolts not lapping of valves. I personaly use anti seize on just about every bolt on the heep
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
post #20 of 22 Old 04-07-2010, 09:53 PM
Burnerman
Burnerman's Avatar
The valve lapping compound is used on the torx BIT. A small dab on the bit helps it bite into the torx bolt head and prevents it from twisting out and stripping the bolt. I use it all the time. Also a note about torx that are stripped out. If you use a drill bit that just fits into the stripped out hole and drill straight it will not damage the threads of the hole. you can drill it straight through and then just clean the threads with the proper size tap. I use Never Seize on bolts that I know I'll be taking out again.
96 ZJ.
post #21 of 22 Old 04-07-2010, 10:17 PM
wrangler76
I used my MIG to weld scrap hex head bolts to the stubborn torx head bolts for the roll bars.... I just used a propane torch to heat the body bolts to include the window and door hinges. Now it seems like I'm pulling things apart so often that they don't get a chance to freeze up. Yeah I know... late addition to this thread.
wrangler76 is offline
post #22 of 22 Old 04-08-2010, 06:23 PM
timatoe
timatoe's Avatar
Originally Posted by RockWoRM View Post
C'mon, now. Rust is a word we just don't use out here.
(but I will PB blast them just in case. hehe. )
I was gonna say, "You guys have obviously never been to Fresno".
Glad you got 'em out.
timatoe is offline
Last Minute Help doherty80 YJ Wrangler Technical Forum 17 09-18-2009 09:45 PM
Any last minute advice? lostsos TJ Wrangler Technical Forum 6 03-06-2007 07:27 AM
Last minute advice Grewe02 TJ Wrangler Technical Forum 8 08-31-2006 05:26 PM
Anyone got a minute? DustinM YJ Wrangler Technical Forum 3 04-04-2006 07:50 PM
10 minute SYE install... crgrissom TJ Wrangler Technical Forum 29 01-16-2006 08:34 PM
